Dear Customers, our warehouse will suspend shipments from June 19th to June 21st (UTC+8) for the Dragon Boat Festival holiday. Customer service replies may be delayed during this period. We sincerely thank you for your support and understanding. Wish you all the best! 😊
7inch IPS LCD Display, 7" 800×480 High Resolution IPS LCD Panel, RGB Interface, IPS Screen, 800×480, Full Color
  • Model:LF70-800480-ARA
  • SKU:26903
  • $17.99
    Out Of Stock
Key parameters
Size 7" Resolution 800×480
Display Panel IPS Viewing Angle 170°
Display Color 16.7M Display colour gamut 50%NTSC
Brightness 550cd/m² (MAX) Contrast ratio 1000:1
Outline Dimension (mm) 164.00(H)×97.00(V)×2.60(T) Display area 153.840(H)×85.632(H)
Pixel pitch (mm) - communication interface RGB888
Operation temperature -20~70°C Storage temperature -30~80°C
RGB Interface Definition
PIN Symbol I/O Description Remark
1 VLED+ P Power for LED backlight (Anode)
2 VLED+ P Power for LED backlight (Anode)
3 VLED- P Power for LED backlight (Cathode)
4 VLED- P Power for LED backlight (Cathode)
5 GND P Power Ground
6 VCOM I Common voltage
7 DVDD P Digital Power
8 MODE I DE/SYNC mode select Note 1
9 DE I Data Input Enable
10 VSYNC I Vertical Sync Input
11 HSYNC I Horizontal Sync Input
12 B7 I Blue data (MSB)
13~17 B6~B2 I Blue data
18 B1 I Blue data Note 2
19 B0 I Blue data (LSB) Note 2
20 G7 I Green data (MSB)
21~25 G6~G2 I Green data
26 G1 I Green data Note 2
27 G0 I Green data (LSB) Note 2
28 R7 I Red data (MSB)
29~33 R6~R2 I Green data
34 R1 I Red data Note 2
35 R0 I Red data (LSB) Note 2
36 GND P Power Ground
37 DCLK I Clock input Note 3
38 GND P Power Ground
39 L/R I Left/Right Selection
40 U/D I Up/Down Selection
41 VGH P Gate ON Voltage
42 VGL P Gate OFF Voltage
43 AVDD P Power for Analog Circuit
44 RESET I Global reset pin
45 NC - No connection
46 VCOM I Common Voltage
47 DITH I Dithering function enable control
48 GND P Power Ground
49 NC - No connection
50 NC - No connection
I: input, O: output, P: power
Note 1: DE/SYNC mode select. Normally pull high.
  • When MODE=H, DE mode.
  • When MODE=L, SYNC mode.
Note 2: When input 18 bits RGB data, the two low bits of R, G and B data must be grounded.
Note 3: Data shall be latched at the falling edge of DCLK.
Dimensions
Selection Guide
PRODUCT SIZE RESOLUTION DISPLAY PANEL DISPLAY COLOR GAMUT BRIGHTNESS (MAX) CONTRAST RATIO OUTLINE DIMENSION (mm) DISPLAY AREA (mm) COMMUNICATION INTERFACE
LF43-800480-ARA
LF43-800480-ARA
4.3" 800×480 IPS 50%NTSC 600cd/m² 1200:1 105.50×67.20×3.00 95.04×53.858 RGB888
LF50-800480-ARA
LF50-800480-ARA
5" 800×480 IPS 50%NTSC 400cd/m² 1000:1 120.90×75.80×2.95 108.0×64.8 RGB888
LF70-800480-TRA
LF70-800480-TRA
7" 800×480 TFT - 500cd/m² 500:1 164.9×100.0×3.5 154.08×85.92 RGB888
LF70-800480-ARA
LF70-800480-ARA
7" 800×480 IPS 50%NTSC 550cd/m² 1000:1 164.00×97.00×2.60 154.84×85.632 RGB888
LF70-1024600-ARA
LF70-1024600-ARA
7" 1024×600 IPS 55%NTSC 400cd/m² 1000:1 164.00×97.00×2.60 154.2144×85.92 RGB888
LF80-8001280-AMA
LF80-8001280-AMA
8" 800×1280 IPS 60%NTSC 500cd/m² 1200:1 114.66×184.16×2.60 107.64×172.22 MIPI
LF101-8001280-AMA
LF101-8001280-AMA
10.1" 800×1280 IPS 60%NTSC 500cd/m² 1200:1 143.0×228.60×2.60 135.36×216.58 MIPI
Display
Size 7inch
Display Panel IPS
Viewing Angle 170°
Brightness 550cd/m²
Communication Interface RGB888
Contrast Ratio 1000:1
Display Color 16.7M
Display Colour Gamut 50%NTSC
Others
Operating Temp. -20~70°C
Storage Temp. -30~80°C
LF70-800480-ARA × 1
