5inch IPS LCD Display, 5" 800×480 High Resolution IPS LCD Panel, RGB Interface, IPS Screen, 800×480, Full Color, Wide Viewing Angle
  • Model:LF50-800480-ARA
  • SKU:26901
  • $16.99
    Out Of Stock
Key parameters
Size 5" Resolution 800×480
Display Panel IPS Viewing Angle 160°
Display Color 16.7M Display colour gamut 50%NTSC
Brightness 400cd/m² (MAX) Contrast ratio 1000:1
Outline Dimension (mm) 120.70(H)×75.80(V)×2.95(T) Display area 108(H)×64.8(V)
Pixel pitch (mm) 0.135(H)×0.135(V) communication interface RGB888
Operation temperature -10~60°C Storage temperature -20~70°C
RGB Interface Definition
PIN Symbol Description
1 K B/L Power input PIN Cathode
2 A B/L Power input PIN anode
3 GND Ground
4 VDD Power input
5~12 R0-R7 Red data
13~20 G0-G7 Green data
21~28 B0-B7 Blue data
29 GND Ground
30 PCLK Data clock signal
31 DISP Standby Mode
DISP="1", Normal Operation
DISP="0", Standby mode.
32 HSYNC Horizontal synchronizing signal
33 VSYNC Vertical synchronizing signal
34 DE Data ENABLE input
35 RESET Reset pin
36 GND Ground
37~40 NC NC
Dimensions
Selection Guide
PRODUCT SIZE RESOLUTION DISPLAY PANEL DISPLAY COLOR GAMUT BRIGHTNESS (MAX) CONTRAST RATIO OUTLINE DIMENSION (mm) DISPLAY AREA (mm) COMMUNICATION INTERFACE
LF43-800480-ARA
LF43-800480-ARA
4.3" 800×480 IPS 50%NTSC 600cd/m² 1200:1 105.50×67.20×3.00 95.04×53.858 RGB888
LF50-800480-ARA
LF50-800480-ARA
5" 800×480 IPS 50%NTSC 400cd/m² 1000:1 120.90×75.80×2.95 108.0×64.8 RGB888
LF70-800480-TRA
LF70-800480-TRA
7" 800×480 TFT - 500cd/m² 500:1 164.9×100.0×3.5 154.08×85.92 RGB888
LF70-800480-ARA
LF70-800480-ARA
7" 800×480 IPS 50%NTSC 550cd/m² 1000:1 164.00×97.00×2.60 154.84×85.632 RGB888
LF70-1024600-ARA
LF70-1024600-ARA
7" 1024×600 IPS 55%NTSC 400cd/m² 1000:1 164.00×97.00×2.60 154.2144×85.92 RGB888
LF80-8001280-AMA
LF80-8001280-AMA
8" 800×1280 IPS 60%NTSC 500cd/m² 1200:1 114.66×184.16×2.60 107.64×172.22 MIPI
LF101-8001280-AMA
LF101-8001280-AMA
10.1" 800×1280 IPS 60%NTSC 500cd/m² 1200:1 143.0×228.60×2.60 135.36×216.58 MIPI
Display
Size 5inch
Resolution 800×480
Display Panel IPS
Viewing Angle 160°
Brightness 400cd/m²
Communication Interface RGB888
Contrast Ratio 1000:1
Display Color 16.7M
Display Colour Gamut 50%NTSC
Pixel Pitch (H×V) 0.135×0.135mm
Others
Operating Temp. -10~60°C
Storage Temp. -20~70°C
LF50-800480-ARA × 1
