4.3inch IPS LCD Display, 4.3" 800×480 High Resolution IPS LCD Panel, RGB Interface, IPS Screen, 800×480, Full Color, Wide Viewing Angle
$15.99
  • Model: LF43-800480-ARA
  • Weight: 0.08kg
  • Dimensions: 105.42mm x 67.07mm x 2.90mm
Key parameters
Size4.3"Resolution800×480
Display PanelIPSViewing Angle160°
Display Color16.7MDisplay colour gamut50%NTSC
Brightness600cd/m² (MAX)Contrast ratio1200:1
Outline Dimension (mm)105.50(H)×67.20(V)×3.00(T)Display area95.04(H)×53.858(V)
Pixel pitch (mm)0.0396(H)×0.1122(V)communication interfaceRGB888
Operation temperature-20~70°CStorage temperature-30~80°C
RGB Interface Definition
PINSymbolDescription
1LED_KBacklight LED ground
2LED_ABacklight LED power
3GNDGround
4VDDPower supply
5~12R0-R7Red data bus
13~20G0-G7Green data bus
21~28B0-B7Blue data bus
29GNDGround
30PCLKData clock
31DISPStandby mode select pin
32HSYNCLine SYNC signal
33VSYNCFrame SYNC signal
34DEData Enable input
35NCNC
36GNDGround
37X1Touch panel control pin
38Y1Touch panel control pin
39X2Touch panel control pin
40Y2Touch panel control pin
Dimensions
Selection Guide
PRODUCTSIZERESOLUTIONDISPLAY PANELDISPLAY COLOR GAMUTBRIGHTNESS (MAX)CONTRAST RATIOOUTLINE DIMENSION (mm)DISPLAY AREA (mm)COMMUNICATION INTERFACE
LF43-800480-ARA
LF43-800480-ARA
4.3"800×480IPS50%NTSC600cd/m²1200:1105.50×67.20×3.0095.04×53.858RGB888
LF50-800480-ARA
LF50-800480-ARA
5"800×480IPS50%NTSC400cd/m²1000:1120.90×75.80×2.95108.0×64.8RGB888
LF70-800480-TRA
LF70-800480-TRA
7"800×480TFT-500cd/m²500:1164.9×100.0×3.5154.08×85.92RGB888
LF70-800480-ARA
LF70-800480-ARA
7"800×480IPS50%NTSC550cd/m²1000:1164.00×97.00×2.60154.84×85.632RGB888
LF70-1024600-ARA
LF70-1024600-ARA
7"1024×600IPS55%NTSC400cd/m²1000:1164.00×97.00×2.60154.2144×85.92RGB888
LF80-8001280-AMA
LF80-8001280-AMA
8"800×1280IPS60%NTSC500cd/m²1200:1114.66×184.16×2.60107.64×172.22MIPI
LF101-8001280-AMA
LF101-8001280-AMA
10.1"800×1280IPS60%NTSC500cd/m²1200:1143.0×228.60×2.60135.36×216.58MIPI
LF43-800480-ARA × 1
Write a review
