LuckFox Pico RV1103 Linux Micro Development Board, Integrates ARM Cortex-A7/RISC-V MCU/NPU/ISP Processors
  • $15.99
  • Price Range $15.99 - $16.99
Processor Cortex [email protected] + RISC-V
NPU 0.5TOPS, supports int4, int8 and int16
ISP Input 4M @30fps (Max)
Memory 64MB DDR2
USB USB 2.0 Host/Device
Camera MIPI CSI 2-lane
GPIO 24 × GPIO pins
Ethernet port 10/100M Ethernet controller and embedded PHY
Default Storage TF card (Not included)
Pinheader options
  • Built-in Rockchip self-developed 4th generation NPU, features high computing precision and supports int4, int8, and int16 hybrid quantization. The computing power of int8 is 0.5 TOPS, and up to 1.0 TOPS with int4
  • Built-in self-developed third-generation ISP3.2, supports 4-Megapixel, with multiple image enhancement and correction algorithms such as HDR, WDR, multi-level noise reduction, etc.
  • Features powerful encoding performance, supports intelligent encoding mode and adaptive stream saving according to the scene, saves more than 50% bit rate of the conventional CBR mode so that the images from camera are high-definition with smaller size, double the storage space
  • Built-in RISC-V MCU supports low power consumption and fast start-up, supports 250ms fast picture capture and loading AI model library at the same time to realize face recognition "in one second"
  • Built-in 16-bit DRAM DDR2, which is capable of sustaining demanding memory bandwidths
  • Integrated with built-in POR, audio codec and MAC PHY
Easier to develop
Integrates TF card slot and camera interface
Application Example
  1. USB Type-C connector
  2. ACT-LED
  3. BOOT button
  4. TF card slot
  5. RV1103
  1. CSI camera interface
    MIPI CSI 2-lane
  2. GPIO header
  3. USB test pads
  4. BOOT test pad
  5. Microphone test pads
  6. Ethernet interface pads
Product Show
PRODUCT Main chip Memory NPU ISP Default Storage FEATURES
Luckfox Pico Mini A
RV1103G1 64MB 0.5TOPS, supports int4, int8 and int16 Input 4M @30fps (Max) TF card (Not included) Onboard Type-C port, MIPI CSI Interface, GPIO, etc.
Luckfox Pico Mini B
SPI NAND FLASH (128MB)
Luckfox Pico
Luckfox Pico Plus
SPI NAND FLASH (128MB) Onboard Type-C port, MIPI CSI Interface, GPIO, Ethernet port, etc.
Luckfox Pico Pro
RV1106G2 128MB Input 5M @30fps (Max) SPI NAND FLASH (256MB) Onboard Type-C port, MIPI CSI Interface, GPIO, Ethernet port, RTC battery header, etc.
Luckfox Pico Max
RV1106G3 256MB
Connectivity
Ethernet RJ45 100M
Memory and Storage
Memory 64MB DDR2
SOC Features
ISP 4MP@30fps
NPU 0.5TOPS
Processor [email protected]
Camera Interface MIPI CSI 2-lane
GPIO 24-Pin
Micro SD Slot
USB USB 2.0 Host/Device, USB Type-C
Luckfox Pico
Luckfox Pico x1
Luckfox Pico
Luckfox Pico M
Luckfox Pico with pre-soldered header x1
Luckfox Pico M
