Luckfox Pico Pro RV1106 Linux Micro Development Board, Integrates ARM Cortex-A7/RISC-V MCU/NPU/ISP Processors,128MB Memory
  • $30.99
  • Price Range $30.99 - $36.99
Processor Cortex [email protected]
NPU Pro: 0.5TOPS, supports int4, int8 and int16
Max: 1TOPS, supports int4, int8 and int16
ISP Input 5M @30fps (Max)
Memory Pro: 128MB DDR3L
Max: 256MB DDR3L
USB USB 2.0 Host/Device
Camera MIPI CSI 2-lane
GPIO 26 × GPIO pins
Ethernet port 10/100M Ethernet controller and embedded PHY
Default Storage SPI NAND FLASH (256MB)
Version and Pinheader options
  • Built-in Rockchip self-developed 4th generation NPU, features high computing precision and supports int4, int8, and int16 hybrid quantization. The int8 computing power of RV1106G2 is 0.5 TOPS, and RV1106G3 is 1.0 TOPS
  • Features powerful encoding performance, supports intelligent encoding mode and adaptive stream saving according to the scene, saves more than 50% bit rate of the conventional CBR mode so that the images from camera are high-definition with smaller size, double the storage space
  • Built-in 16-bit DRAM DDR3L, which is capable of sustaining demanding memory bandwidths
  • Integrated with built-in POR, audio codec and MAC PHY
Easier to develop
Integrates TF card slot, camera interface and Ethernet port
SLC NAND FLASH
For a better user experience
Application Example
  1. USB Type-C connector
  2. ACT-LED
  3. BOOT button
  4. RESET button
  5. TF card slot
  6. RV1106
    Vision processor SoC with built-in ARM Cortex-A7 core (RV1106G2 for Pro version, RV1106G3 for Max version)
  7. RTC battery header
    MX1.25 connector, for connecting RTC battery
  1. CSI camera interface
    MIPI CSI 2-lane
  2. RJ45 Ethernet port
  3. USB test pads
    TP1: USB_N
    TP2: USB_P
  4. USB detection test pad
  5. W25N02KV
    256MB SLC NAND FLASH
  6. GPIO header
Product Show
Connectivity
Ethernet RJ45 100M
Memory and Storage
Flash 256MB
Memory 128MB DDR2
SOC Features
ISP 5MP@30fps
NPU 0.5TOPS
Processor [email protected]
Camera Interface MIPI CSI 2-lane
GPIO 26-PIN
Micro SD Slot
USB USB 2.0 Host/Device, Type-C
Luckfox Pico Pro
Luckfox Pico Pro x1
Luckfox Pico Pro M
Luckfox Pico Pro with pre-soldered header x1
Luckfox Pico Max
Luckfox Pico Max x1
Luckfox Pico Max M
Luckfox Pico Max with pre-soldered header x1
