Luckfox Pico Max RV1106 Linux Micro Development Board, Integrates ARM Cortex-A7/RISC-V MCU/NPU/ISP Processors,256MB Memory
New
$14.99
  • Model: Luckfox Pico Max
  • Weight: 0.01kg
  • SKU: 25719
ProcessorCortex A7@1.2GHz
NPU0.5TOPS, supports int4, int8 and int16
ISPInput 5M @30fps (Max)
MemoryPro: 128MB DDR2
Max: 256MB DDR2
USBUSB 2.0 Host/Device
CameraMIPI CSI 2-lane
GPIO26 × GPIO pins
Ethernet port10/100M Ethernet controller and embedded PHY
Default StorageSPI NAND FLASH (256MB)
Version and Pinheader options
  • Built-in Rockchip self-developed 4th generation NPU, features high computing precision and supports int4, int8, and int16 hybrid quantization. The computing power of int8 is 0.5 TOPS, and up to 1.0 TOPS with int4
  • Features powerful encoding performance, supports intelligent encoding mode and adaptive stream saving according to the scene, saves more than 50% bit rate of the conventional CBR mode so that the images from camera are high-definition with smaller size, double the storage space
  • Built-in 16-bit DRAM DDR2, which is capable of sustaining demanding memory bandwidths
  • Integrated with built-in POR, audio codec and MAC PHY
Easier to develop
Integrates TF card slot, camera interface and Ethernet port
SLC NAND FLASH
For a better user experience
Application Example
  1. USB Type-C connector
  2. ACT-LED
  3. BOOT button
  4. RESET button
  5. TF card slot
  6. RV1106
    Vision processor SoC with built-in ARM Cortex-A7 core (RV1106G2 for Pro version, RV1106G3 for Max version)
  1. RTC battery header
    MX1.25 connector, for connecting RTC battery
  2. CSI camera interface
    MIPI CSI 2-lane
  3. RJ45 Ethernet port
  4. USB test pads
  5. BOOT test pad
  6. W25N02KV
    256MB SLC NAND FLASH
  7. GPIO header
Product Show
PRODUCTMain chipMemoryNPUISPDefault StorageFEATURES
Luckfox Pico Mini A
RV1103G164MB0.5TOPS, supports int4, int8 and int16Input 4M @30fps (Max)TF card (Not included)Onboard Type-C port, MIPI CSI Interface, GPIO, etc.
Luckfox Pico Mini B
SPI NAND FLASH (128MB)
Luckfox Pico
Luckfox Pico Plus
SPI NAND FLASH (128MB)Onboard Type-C port, MIPI CSI Interface, GPIO, Ethernet port, etc.
Luckfox Pico Pro
RV1106G2128MBInput 5M @30fps (Max)SPI NAND FLASH (256MB)Onboard Type-C port, MIPI CSI Interface, GPIO, Ethernet port, RTC battery header, etc.
Luckfox Pico Max
RV1106G3256MB
Luckfox Pico Pro
Luckfox Pico Pro x1
Luckfox Pico Pro M
Luckfox Pico Pro with pre-soldered headerx1
Luckfox Pico Max
Luckfox Pico Max x1
Luckfox Pico Max M
Luckfox Pico Max with pre-soldered header x1
Write a review
Note: HTML is not translated!
Bad Good
