Luckfox Pico Mini B RV1103 Linux Micro Development Board, Integrates ARM Cortex-A7/RISC-V MCU/NPU/ISP Processors,onboard 64MB memory, with 128MB FLASH
New
$8.99
  • Model: Luckfox Pico Mini B
  • Weight: 0.04kg
  • SKU: 25722
Luckfox Pico Mini RV1103 Linux Micro Development Board, Integrates ARM Cortex-A7/RISC-V MCU/NPU/ISP Processors
ProcessorCortex A7@1.2GHz + RISC-V
NPU0.5TOPS, supports int4, int8 and int16
ISPInput 4M @30fps (Max)
Memory64MB DDR2
USBUSB 2.0 Host/Device
CameraMIPI CSI 2-lane
GPIO17 × GPIO pins
Default StorageMini A: TF card (Not included)
Mini B: SPI NAND FLASH (128MB)
Version and Pinheader options
Exquisite appearance, compact size
Castellated Holes With Immersion Gold Design, Highly Integrated Packaging, Easy To Embed Into Various Product Applications
  • Built-in Rockchip self-developed 4th generation NPU, features high computing precision and supports int4, int8, and int16 hybrid quantization. The computing power of int8 is 0.5 TOPS, and up to 1.0 TOPS with int4
  • Built-in self-developed third-generation ISP3.2, supports 4-Megapixel, with multiple image enhancement and correction algorithms such as HDR, WDR, multi-level noise reduction, etc.
  • Features powerful encoding performance, supports intelligent encoding mode and adaptive stream saving according to the scene, saves more than 50% bit rate of the conventional CBR mode so that the images from camera are high-definition with smaller size, double the storage space
  • Built-in RISC-V MCU supports low power consumption and fast start-up, supports 250ms fast picture capture and loading AI model library at the same time to realize face recognition "in one second"
  • Built-in 16-bit DRAM DDR2, which is capable of sustaining demanding memory bandwidths
  • Integrated with built-in POR, audio codec and MAC PHY
Easier to develop
Integrates TF card slot and camera interface
SLC NAND FLASH
For a better user experience
Application Example
Suitable for more application scenarios
  1. USB Type-C connector
  2. ACT-LED
    system operation status indicator (in the default system)
  3. USER-LED
  4. BOOT button
  1. SLC NAND FLASH
    Only available on the B version, and reserved pads for A version
  2. CSI camera interface
    MIPI CSI 2-lane
  3. TF card slot
  4. RV1106
Product Show
PRODUCTMain chipMemoryNPUISPDefault StorageFEATURES
Luckfox Pico Mini A
RV1103G164MB0.5TOPS, supports int4, int8 and int16Input 4M @30fps (Max)TF card (Not included)Onboard Type-C port, MIPI CSI Interface, GPIO, etc.
Luckfox Pico Mini B
Luckfox Pico
Luckfox Pico Plus
SPI NAND FLASH (128MB)Onboard Type-C port, MIPI CSI Interface, GPIO, Ethernet port, etc.
Luckfox Pico Pro
RV1106G2128MBInput 5M @30fps (Max)SPI NAND FLASH (256MB)Onboard Type-C port, MIPI CSI Interface, GPIO, Ethernet port, RTC battery header, etc.
Luckfox Pico Max
RV1106G3256MB
Luckfox Pico Mini A
Luckfox Pico Mini A x1
Luckfox Pico Mini A M
Luckfox Pico Mini A with pre-soldered headerx1
Luckfox Pico Mini B
Luckfox Pico Mini B x1
Luckfox Pico Mini B M
Luckfox Pico Mini B with pre-soldered header x1
Write a review
Note: HTML is not translated!
Bad Good
