LuckFox Pico Plus RV1103 Linux Micro Development Board, Integrates ARM Cortex-A7/RISC-V MCU/NPU/ISP Processors, With Ethernet Port
$9.99
  • Model: Luckfox Pico Plus
  • Weight: 0.01kg
  • SKU: 25189
  • Battery: Not included
Date First Available: 2023-08-15
ProcessorCortex A7@1.2GHz + RISC-V
NPU0.5TOPS, supports int4, int8 and int16
ISPInput 4M @30fps (Max)
Memory64MB DDR2
USBUSB 2.0 Host/Device
CameraMIPI CSI 2-lane
GPIO25 × GPIO pins
Ethernet port10/100M Ethernet controller and embedded PHY
Default StorageSPI NAND FLASH (128MB)
Pinheader options
  • Built-in Rockchip self-developed 4th generation NPU, features high computing precision and supports int4, int8, and int16 hybrid quantization. The computing power of int8 is 0.5 TOPS, and up to 1.0 TOPS with int4
  • Built-in self-developed third-generation ISP3.2, supports 4-Megapixel, with multiple image enhancement and correction algorithms such as HDR, WDR, multi-level noise reduction, etc.
  • Features powerful encoding performance, supports intelligent encoding mode and adaptive stream saving according to the scene, saves more than 50% bit rate of the conventional CBR mode so that the images from camera are high-definition with smaller size, double the storage space
  • Built-in RISC-V MCU supports low power consumption and fast start-up, supports 250ms fast picture capture and loading AI model library at the same time to realize face recognition "in one second"
  • Built-in 16-bit DRAM DDR2, which is capable of sustaining demanding memory bandwidths
  • Integrated with built-in POR, audio codec and MAC PHY
Easier to develop
Integrates TF card slot, camera interface and Ethernet port
SLC NAND FLASH
For a better user experience
Application Example
  1. USB Type-C connector
  2. ACT-LED
  3. TF card slot
  4. BOOT button
  5. W25N01GV
    1Gb SLC NAND FLASH
  6. RV1103
  1. CSI camera interface
    MIPI CSI 2-lane
  2. RJ45 Ethernet port
  3. GPIO header
  4. USB test pads
  5. BOOT test pad
  6. Microphone test pads
Product Show
PRODUCTMain chipMemoryNPUISPDefault StorageFEATURES
Luckfox Pico Mini A
RV1103G164MB0.5TOPS, supports int4, int8 and int16Input 4M @30fps (Max)TF card (Not included)Onboard Type-C port, MIPI CSI Interface, GPIO, etc.
Luckfox Pico Mini B
Luckfox Pico
Luckfox Pico Plus
SPI NAND FLASH (128MB)Onboard Type-C port, MIPI CSI Interface, GPIO, Ethernet port, etc.
Luckfox Pico Pro
RV1106G2128MBInput 5M @30fps (Max)SPI NAND FLASH (256MB)Onboard Type-C port, MIPI CSI Interface, GPIO, Ethernet port, RTC battery header, etc.
Luckfox Pico Max
RV1106G3256MB
Luckfox Pico Plus
Luckfox Pico Plus x1
Luckfox Pico Plus
Luckfox Pico Plus M
Luckfox Pico Plus with pre-soldered header x1
Luckfox Pico Plus M
Connectivity
EthernetRJ45 100M
Memory and Storage
Flash128MB
Memory64MB DDR2
SOC Features
ISP4MP@30fps
NPU0.5TOPS
ProcessorSingle-core@1.2GHz
Camera InterfaceMIPI CSI 2-lane
GPIO25-PIN
Micro SDSlot
USBUSB 2.0 Host/Device, Type-C
