Luckfox Pico Zero Linux Micro Development Board, Based On Luckfox RV1106G3 Chip, 1 TOPS Computing Power, 8GB eMMC, With Wireless Module
  • Model:Luckfox Pico Zero
  • SKU:32111
  • $46.99
    In Stock
Luckfox Pico Zero
The Luckfox Pico Zero is a cost-effective Linux micro development board, based On Luckfox RV1106G3 chip to provide a simple and efficient development platform for developers. Supports a variety of interfaces including MIPI CSI, GPIO, UART, SPI, I2C and USB etc., with an onboard wireless module, which is ideal for a wide range of embedded applications.
Luckfox Pico Zero Linux Micro Development Board, front view Luckfox Pico Zero Linux Micro Development Board, features
Luckfox Pico Zero Linux Micro Development Board, highly integrated and powerful performance
  • Built-in Rockchip self-developed 4th generation NPU, features high computing precision and supports int4, int8, and int16 hybrid quantization. The int8 computing power of RV1106G3 is 1TOPS
  • Built-in self-developed third-generation ISP3.2, supports 8-Megapixel, with multiple image enhancement and correction algorithms such as HDR, WDR, multi-level noise reduction, etc.
  • Features powerful encoding performance, supports intelligent encoding mode and adaptive stream saving according to the scene, saves more than 50% bit rate of the conventional CBR mode so that the images from the camera are high-definition with a smaller size
  • Built-in 16-bit 256MB DRAM DDR3L, which is capable of sustaining demanding memory bandwidths
Wi-Fi 6 and Bluetooth module
Onboard 2.4GHz WiFi 6 and Bluetooth 5.2 (LE) Bluetooth Module
Providing Stable Connection And Efficient Transmission
Luckfox Pico Zero Linux Micro Development Board, onboard Wi-Fi 6 and Bluetooth module
Antenna Switching
Flexible Switching Between External Antenna and Onboard Antenna to meet more usage scenarios
Luckfox Pico Zero Linux Micro Development Board, antenna switching
MIPI CSI 4-lane Interface
Composed of dual MIPI-CSI (2-lane) interfaces
Luckfox Pico Zero Linux Micro Development Board, onboard MIPI CSI 4-lane interface
* for reference only, please refer to the Package Content for the detailed part list.
The resolution of the camera shown in the picture is 1280 × 1080. This product supports up to 3840 × 2160 (8M) @15FPS input.
Multiple Audio Interfaces
Onboard microphone + speaker header
meets a variety of audio application scenarios
Luckfox Pico Zero Linux Micro Development Board, multiple audio interfaces
meets a variety of application scenarios
Luckfox Pico Zero Linux Micro Development Board,  meets a variety of application scenarios
Luckfox Pico Zero Linux Micro Development Board, pin definition Luckfox Pico Zero Linux Micro Development Board, pin definition
Luckfox Pico Zero Linux Micro Development Board, onboard components
  1. RV1106G3
    Vision processor SoC, integrates ARM Cortex-A7 core
  2. USB-C Port
  3. USER-LED
    for indicating system operating status in the default image
  4. RESET Button
  5. BOOT Button
  6. Speaker Header
    MX1.25 2P connector, supports 8Ω 1W speaker.
  7. RTC Battery Header
  1. External Antenna Connector
  2. Onboard Antenna
  3. Wi-Fi / Bluetooth Module
    2.4GHz Wi-Fi 6 / Bluetooth 5.2 (LE) module
  4. Onboard Microphone
  5. 40PIN GPIO Header
    Compatible with some Raspberry Pi HATs
  6. Camera Interface
    MIPI CSI (4-lane)
  7. TF Card Slot
    Supports storage expansion only
  8. 8GB eMMC
Luckfox Pico Zero Linux Micro Development Board, outline dimensions
Connectivity
Bluetooth Bluetooth 5.2 (LE)
Wi-Fi 2.4GHz Wi-Fi 6
Memory and Storage
eMMC 8GB
Memory 256MB DDR3L
SOC Features
ISP 8M@15fps
NPU 1TOPS
Processor ARM Cortex-A7
Video Encoding 5M@30FPS
Audio Ouput MX1.25 2P connector
Camera Interface MIPI CSI (4-lane)
GPIO 40PIN
Micro SD Slot
Microphone Onboard microphone
Luckfox Pico Zero
Luckfox Pico Zero x1
Luckfox Pico Zero
