ISG1321 1.38MP Mono Camera Module, Global Shutter, 95.5° FOV Wide Angle Lens, Supports 1280 × 1080@120fps Output
  • Model:ISG1321 Camera
  • SKU:32175
  • $22.99
    In Stock
ISG1321 1.38MP mono
global shutter camera module
equipped with a 95.5° FOV wide angle distortion-free lens
ISG1321-Camera, camera front view ISG1321-Camera, function
Sensor ISG1321 CMOS size 1/4 inch
Camera type mono Pixels 1.38MP (1280 x 1080)
Shutter Global Shutter Output 120 FPS (MAX)
Interface MIPI-CSI (2-lane) Aperture F2.4
Distortion < 1% FOV 95.5°
Focal length 2.88mm Focusing Manual focus
Applications Machine Vision, Logistics Barcode Reading, and Industrial Inspection
Wide field of view
Onboard 95.5° wide angle lens, provides a wider picture range and viewing angle
Large FOV, onboard 95.5° wide angle lens
Global Shutter
All pixels are exposed simultaneously, capturing images without distortion
ISG1321-Camera, features global Shutter
High Frame Rate
Supports up to 1280×1080@120fps, enabling precise capture of fast-moving objects
Connects to Luckfox Pico Zero
ISG1321-Camera, Connects to Luckfox Pico Zero
* for reference only, the Luckfox Pico Zero is NOT included.
ISG1321-Camera, outline dimensions
Camera
Aperture F2.4
Camera type mono
CMOS size 1/4″
Distortion <1%
Focal length 2.88mm
FOV 95.5°
Pixel 1.38MP (1280 x 1080)
Sensor ISG1321
Camera Interface MIPI-CSI (2-lane)
  1. ISG1321 Camera x1
  2. 22PIN FFC cable ~200mm x1
ISG1321-Camera
FFC-22PIN-0.5-200mm
