Luckfox Lyra Ultra RK3506B Linux Micro Development Board, Onboard 8GB eMMC, Integrates Triple-core ARM Cortex-A7 and ARM Cortex-M0 Processors
New
$18.99
  • Model: Luckfox Lyra Ultra
  • Weight: 0.05kg
  • Dimensions: 55.00mm x 40.00mm x 0.00mm
Luckfox Lyra RK3506B Linux Micro Development Board, front view Luckfox Lyra RK3506B Linux Micro Development Board, features
Development Board Versions
Luckfox Lyra Ultra series, version options
ModelLuckfox Lyra UltraLuckfox Lyra Ultra W
ProcessorTriple-core Arm Cortex-A7 (1.2Ghz) + Arm Cortex-M0
Memory512MB DDR3L
USBUSB OTG2.0 × 2Original USB OTG2.0 × 1,
Extended USB HOST2.0 × 2 via HUB
DisplayMIPI DSI 2-lane
GPIO29 × Rockchip Matrix IO pins + 4 × GPIO pins
Ethernet port10/100M Ethernet port
Default Storage8GB eMMC
Wireless-Onboard 2.4GHz WiFi 6 / Bluetooth 5.2 / BLE
LCD Kit Selection
Optional for 10.1-DSI-TOUCH-A kit
Luckfox Lyra RK3506B Linux Micro Development Board, LCD Kit Selection
LCD Kit connection example
Luckfox Lyra Ultra series, LCD Kit connection example
Luckfox Lyra RK3506B Linux Micro Development Board, adopts RK3506B chip
  • Triple-core ARM Cortex-A7 32-bit core, with integrated VFP to support single- and double-precision floating-point operations
  • Built-in ARM Cortex-M0 MCU design, supports SMP and AMP configuration
  • Supports DDR2 / DDR3 / DDR3L memory interface expansion, meeting various expansion needs
  • The low-speed interfaces adopt Rockchip Matrix IO design, which allows rich function signals to share the limited chip pins, making peripheral circuit adaptation more flexible
  • Built-in audio and video codec, supports multiple audio inputs and outputs, providing high-quality audio playback and recording functions
Easier to develop
Integrates DSI interface, USB-A port, Ethernet port, and speaker header, etc.
Luckfox Lyra RK3506B Linux Micro Development Board, integrates DSI interface, USB-A port, Ethernet port, and speaker header
WiFi 6 and Bluetooth module
Onboard 2.4GHz WiFi 6 and Bluetooth 5.2/BLE Bluetooth Module, Providing Stable Connection And Efficient Transmission
Luckfox Lyra Ultra series, onboard WiFi 6 and Bluetooth module
Reserved PoE Module Header
Luckfox Lyra Ultra series, optional for PoE Module Luckfox Lyra Ultra series, supports PoE power supply
* the PoE module is optional, and the switch in the picture above is NOT included.
MIPI DSI 2-lane interface
Compact size, powerful performance, easy to drive large screens
Luckfox Lyra Ultra RK3506B Linux Micro Development Board, onboard MIPI DSI 2-lane interface
* Supports up to 1280 × 800 @ 60Hz resolution.
The Rockchip Matrix IO supports 98 multiplexed functions and allows flexible pinout configuration
Luckfox Lyra Ultra RK3506B Linux Micro Development Board, adopts Rockchip Matrix IO design
Luckfox Lyra Ultra RK3506B Linux Micro Development Board, suitable for more application examples
Luckfox Lyra Ultra RK3506B Linux Micro Development Board, pin definition
Luckfox Lyra Ultra RK3506B Linux Micro Development Board, onboard components
  1. Type-C connector
  2. USER-LED
    for indicating system operation status in the default image, programmable indicator
  3. BOOT button
  4. RESET button
  5. GPIO header
  6. RTC battery connector
  7. Antenna connector
  8. WIFI/Bluetooth module
    2.4G WiFi 6; BT5.2/BLE Bluetooth module
  9. USB-A port
  10. RJ45 100M Ethernet port
  11. Speaker header
    MX1.25 2P connector, supports 8Ω 1W speaker
  1. MX1.25 4P USB header
    Supports conversion to USB-A interface (only available on versions with Wi-Fi module)
  2. DSI display interface
    MIPI CSI 2-lane
  3. 512MB DDR3L
  4. RK3506B
    Multi-core heterogeneous SoC with tri-core ARM Cortex-A7 + ARM Cortex-M0
  5. PoE module / external power supply header
    for connecting external 5V power supply or PoE module power supply
  6. PoE module header
  7. CH334F
    USB HUB chip
  8. CH182H2
    100 Mbps Ethernet PHY chip
  9. 8GB EMMC
Luckfox Lyra Ultra RK3506B Linux Micro Development Board, outline dimensions
Resources & Services
Luckfox Lyra Ultra
  1. Luckfox Lyra Ultra x1
  2. USB Type-A to Type-C cable ~1m x1
Luckfox Lyra Ultra
  1. Luckfox Lyra Ultra W x1
  3. IPX 2.4G 2DB antenna x1
Luckfox Lyra Ultra PoE Kit
  2. Luckfox PoE module x1
  3. USB Type-A to Type-C cable ~1m x1
  4. Screws pack x1
Luckfox Lyra Ultra W PoE Kit
  3. Screws pack x1
  4. USB Type-A to Type-C cable ~1m x1
  5. IPX 2.4G 2DB antenna x1
Luckfox Lyra Ultra LCD Kit A
  2. 10.1-DSI-TOUCH-A x1
  3. MX1.25 2PIN to MX1.25 4PIN cable ~150mm x1
  4. MIPI-DSI-Cable-12cm x1
  5. MX1.25 2PIN to 2.54 3P cable x1
  6. FFC 22PIN cable ~200mm x2
  7. USB Type-A to Type-C cable ~1m x1
Luckfox Lyra Ultra LCD Kit B
  7. Luckfox PoE module x1
  8. Screws pack x1
  9. USB Type-A to Type-C cable ~1m x1
Luckfox Lyra Ultra W LCD Kit A
  8. IPX 2.4G 2DB antenna x1
Luckfox Lyra Ultra W LCD Kit B
  8. Screws pack x1
  9. IPX 2.4G 2DB antenna x1
  10. USB Type-A to Type-C cable ~1m x1
Write a review
