Luckfox Core3576 Edge Computing Development Board, Rockchip RK3576 Octa-Core 2.2GHz Processor, Features A big.LITTLE Architecture, 6 TOPS Computing Power NPU
  • $129.99
  • Price Range $129.99 - $221.99
Powered By Luckfox Core3576 Module To Enable AI Edge Computing,
Making It Easy For You To Explore The World Of AI
Luckfox Core3576 Edge Computing Development Board, front view Luckfox Core3576 Edge Computing Development Board, features
Version Options
Luckfox-Omni3576 Development Board
Core3576 module + base board, without case
Luckfox-Omni3576-04000-Box
Luckfox-Omni3576 Box Kit
Core3576 module + base board + Aluminum alloy case
Processor Quad-core Arm [email protected] + Quad-core Arm [email protected]
RAM Options for 4 / 8GB LPDDR4X RAM
eMMC Options for 0 / 32 / 64GB eMMC Flash
NPU 6 TOPS@INT8, supports INT4, INT8, INT16, FP16, BF16, TF32 mixed operation
GPU ARM Mali G52 [email protected], supports OpenGL ES 1.1/2.0/3.2, OpenCL 2.0 and Vulkan 1.1, built-in high-performance 2D/3D acceleration hardware
ISP Built-in 16MP ISP, supports multiple algorithm accelerators such as HDR, 3A, CAC, 3DNR, 2DNR, Sharpening, Dehaze, Enhance, Debayer, and small-angle lens distortion correction, etc.
Video Decoding: 4K@120fps (H.265/HEVC, VP9, AVS2, AV1); 4K@60fps (H.264/AVC)
Encoding: 4K@60fps (H.265/HEVC, H.264/AVC)
Storage TF card slot
M.2 connector × 1 (PCIe NVMe SSD support, compatible with 2242/2260/2280 size)
Connectivity 1000M Ethernet port × 2
Onboard wireless module supporting 2.4GHz/5GHz dual-band Wi-Fi6 and Bluetooth 5.2/BLE
Video Output HDMI2.1 (4K@120fps) port × 1
4-lane MIPI DSI (2K@60fps) interface × 1
Video Input 4-lane MIPI CSI camera interface × 2
USB USB Type-C (5Gbps/DP) × 1, supports OTG and image burning
USB3.2 Gen1 port (5Gbps) × 1
USB2.0 port × 3
CAN Supports high-speed CAN FD and CAN2.0A/B data communication.
Audio Onboard microphone
3Pin MX1.25 audio output header
GPIO 40Pin GPIO header (compatible with most Raspberry Pi HATs)
System Support Buildroot, Debian, Android 14
Power input 5V DC
Ambient temperature Operating temperature: 0°C ~ 60°C
Storage temperature: 0°C ~ 70°C
Storage humidity: 10% ~ 90%RH (no condensation)
Others Onboard IR receiver with 38KHz carrier frequency
2Pin SH1.0 RTC battery header
5V fan header
Low Power Octa-Core AIoT Processor
Equipped with high-performance RK3576 processor, integrated with quad-core Cortex-A72 and quad-core Cortex-A53, providing strong performance and high energy efficiency
Luckfox Core3576 Edge Computing Development Board, with Octa-Core AIoT processor
Equipped with 6 TOPS computing power, easy to convert a variety of neural network models based on TensorFlow, MXNet, PyTorch, and Caffe frameworks.
Luckfox Core3576 Edge Computing Development Board, Object Recognition demo
Object Recognition
Luckfox Core3576 Edge Computing Development Board, Face Recognition demo
Face Recognition
Luckfox Core3576 Edge Computing Development Board, Vehicle Recognition demo
Vehicle Recognition
Luckfox Core3576 Edge Computing Development Board, Pedestrian Detection demo
Luckfox Core3576 Edge Computing Development Board, Text Recognition demo
Text Recognition
Luckfox Core3576 Edge Computing Development Board, Semantic Segmentation demo
Luckfox Core3576 Edge Computing Development Board, supports a variety of neural network models
Supports 4K Encoding and Decoding
Supports 4K@120fps (H.265/HEVC, VP9, AVS2, AV1), 4K@60fps (H.264/AVC) decoding and 4K@60fps (H.265/HEVC, H.264/AVC) encoding, easy to deal with HD video tasks
Luckfox Core3576 Edge Computing Development Board, supports 4K encoding and decoding
Dual Gigabit Ethernet Interfaces
Different types of traffic can be distributed to different network interfaces: one for external Internet connection and another for internal LAN, which improves security and management flexibility
Luckfox Core3576 Edge Computing Development Board, supports dual gigabit ethernet
Note: the ETH1 port can support PoE power supply function through a PoE module.
Dual Camera Interfaces
Suitable for vision robotics, depth vision, stereo vision and other AI vision applications
Luckfox Core3576 Edge Computing Development Board, with dual camera interfaces
Customized Aluminum Alloy Case for Highly Efficient and Silent Heat Dissipation
Optional for customized Aluminum alloy case with fins for Omni3576 development board, increases the contact and heat dissipation area between the metal case and the air to make the heat dissipation more efficient, with no frequency dropout for 24 hours at full load. Adopts passive fanless cooling design to greatly reduce dust accumulation, thus minimizing malfunctions.
Luckfox Core3576 Edge Computing Development Board, optional for customized Aluminum Alloy case
What's on board
Luckfox Core3576 Edge Computing Development Board, with rich peripheral interfaces
With Aluminum alloy case
Luckfox Core3576 Edge Computing Development Board, with case
Application Examples
Widely used in edge computing, local deployment of large models, intelligent commercial displays, cloud terminal products, industrial control hosts, automotive electronics, and more
Luckfox Core3576 Edge Computing Development Board, application examples
Luckfox Core3576 Edge Computing Development Board, outline dimensions
Connectivity
Bluetooth Bluetooth 5.2
Ethernet 1000M Ethernet × 2
Infrared 38KHz input
Wi-Fi 2.4GHz/5GHz Wi-Fi6
Memory and Storage
Flash 0 / 32 / 64GB
Memory M.2 M Key
SOC Features
GPU 0.9GHz
ISP 16MP
NPU 6TOPS
Processor [email protected]
Video Decoding 4K@120fps
Video Encoding 4K@60fps
Audio Ouput Onboard microphone
Camera Interface MIPI CSI 4-lane × 2
Display Interface MIPI DSI 4-lane; hdmi2.1
GPIO 40-PIN
Micro SD Slot
USB USB Type-C (OTG) ; USB3.2 Gen1; USB2.0 × 3
Others
Operating Temp. 0°C ~ 60°C
Power input 5V DC
Storage Temp. 0°C ~ 70°C
Luckfox-Omni3576-0xxxx
OPTIONS Luckfox-Omni3576 Development Board (including Core3576 module + base board) x 1
Luckfox-Omni3576-0xxxx-Box
OPTIONS Luckfox-Omni3576 Box Kit (including Core3576 module + base board + Aluminum alloy case) x 1
