10.1inch DSI Capacitive Touch Display, 800×1280, IPS Panel, Optical Bonding Toughened Glass Panel, 10-Point Touch
$59.99
- Stock: In Stock
- Model: 10.1-DSI-TOUCH-A
- Weight: 0.74kg
- SKU: 30052
- Battery: Not included
Date First Available: 2025-01-10
10.1″ DSI Capacitive Touch Display
The display orientation is portrait by default, with 800×1280 resolution (H×V). Change the software config for landscape display.
Device & System Support
connection examples
Connecting to Raspberry Pi 5
Connecting to ESP32-P4-NANO
Connecting to Luckfox-Omni3576 Development Board
Thinner and more space-saving
Integrates the driver circuit into an FPC cable, the total thickness of the LCD is only 10.8mm
IPS Display Panel
Excellent Display Performance With 178° Wide Viewing Angle
10-Point Capacitive Touch
Gently touch, and see what you get, enjoy multi-point UI interaction via flexible operation. Adapting touch function via I2C signal, supports 10-point touch
interface definition
Supports backlight adjustment via software
Resources & Services
- 10.1-DSI-TOUCH-A x1
- MIPI-DSI-Cable-12cm x1
- MX 1.25 2PIN to 2.54 3PIN cable x1
- FFC 22PIN cable ~200mm (opposite sides) x2
- MX 1.25 2PIN to 2.54 4PIN cable x1
- Screws pack x1
| Display | |
| Size | 10.1inch |
| Resolution | 800×1280 |
| Display Panel | IPS |
| Viewing Angle | 178° |
| Brightness | 500cd/㎡ |
| Communication Interface | DSI |
| Pixel Pitch (H×V) | 0.16967×0.16995mm |
| Touch | |
| Touch Panel | Toughened Glass |
| Touch Panel Tech | Optical Bonding |
| Touch Point | 10-Point |
| Touch Type | Capacitive |
| Device & System Support | |
| ESP32-P4 | Supports LVGL GUI programs |
| Raspberry Pi | Supports Raspberry Pi OS |
| RK3506 | Supports Buildroot / Ubuntu, etc. |
| RK3576 | Supports Buildroot / Debian / Ubuntu / Android, etc. |
