Core3566104032 Module, CM4 to Pi4B Adapter Board + 8inch touch Display Kit, Rockchip RK3566 Quad-core Processor, Compatible With Raspberry Pi CM4
$146.99
  • Model: Core3566-Kit-H
  • Weight: 0.76kg
  • SKU: 25019
NPU0.8 TOPS @INT8
GPUArm Mali-G52 2EE
USB 2.0 × 1
PCIe Gen 2 x 1
28 GPIO signals
Operating Voltage5V DC
Dimensions55 × 40 × 4.7mm
Core3566 Module
Kit Selection Guide
KitABCDEFGH
Necessary accessories
Core3566102032
Core3566104032
CM4-IO-BASE-A
CM4-to-Pi4-Adapter
HDMI to Micro HDMI Adapter
IMX219-77 Camera
4.3inch DSI LCD
8DP-CAPLCD
High speed WiFi and Bluetooth
Product details
Onboard Resources
Product show
Ordering Codes
ModelWirelessRAMeMMC Flash
Core35661 = Yes
0 = No
02 = 2GB
04 = 4GB
000 = 0GB (Lite)
032 = 32GB
Core3566104032
Core3566002000×2GB0GB (Lite)
Core3566002032×2GB32GB
Core3566004000×4GB0GB (Lite)
Core3566004032×4GB32GB
Core35661020002GB0GB (Lite)
Core35661020322GB32GB
Core35661040004GB0GB (Lite)
Core35661040324GB32GB
Certificate of Authorization
Resources & Services
Core3566-Kit-A/B
  1. CM4-IO-BASE-A x1
  5. 1PIN cable (4PCS) x1
Core3566-Kit-C/D
  1. CM4-to-Pi4-Adapter x1
  6. 1PIN cable (4PCS) x1
Core3566-Kit-E
  1. CM4-IO-BASE-A x1
  2. Core3566104032 x1
  5. IMX219-77 Camera x1
Core3566-Kit-F
  7. 1PIN cable (4PCS) x1
Core3566-Kit-G
  1. CM4-IO-BASE-A x1
Core3566-Kit-H
Write a review
