Core3566102032 Module, CM4 Base Board Kit, Rockchip RK3566 Quad-core Processor, Compatible With Raspberry Pi CM4
  • $120.99
Processor Quad-core Arm Cortex-A55 @1.8GHz
Memory Options for 2GB/4GB LPDDR4 SDRAM memory
Storage Options for 0GB (Lite) or 32GB eMMC Flash
NPU 0.8 TOPS @INT8
GPU Arm Mali-G52 2EE
Connectivity Optional dual-band (2.4GHz/5.0GHz) IEEE 802.11b/g/n/ac wireless WiFi, Bluetooth 5.0, BLE, supports external antenna
USB 2.0 × 1
PCIe Gen 2 x 1
28 GPIO signals
Video HDMI interface (4Kp60 supported)
Multimedia 4Kp60 H.264/H.265/VP9 (decode), 1080p60 H.264/H.265 (encode)
Operating Voltage 5V DC
Operating Temp. -10°C ~ 80°C ambient
Dimensions 55 × 40 × 4.7mm
Core3566 Module
Kit Selection Guide
Kit A B C D E F G H
Necessary accessories
Core3566102032
Core3566104032
CM4-IO-BASE-A
CM4-to-Pi4-Adapter
HDMI to Micro HDMI Adapter
IMX219-77 Camera
4.3inch DSI LCD
8DP-CAPLCD
High speed WiFi and Bluetooth
Product details
Onboard Resources
Product show
Ordering Codes
Model Wireless RAM eMMC Flash
Core3566 1 = Yes
0 = No
02 = 2GB
04 = 4GB
000 = 0GB (Lite)
032 = 32GB
Core3566 1 04 032
Part Number Wireless RAM eMMC Flash
Core3566002000 × 2GB 0GB (Lite)
Core3566002032 × 2GB 32GB
Core3566004000 × 4GB 0GB (Lite)
Core3566004032 × 4GB 32GB
Core3566102000 2GB 0GB (Lite)
Core3566102032 2GB 32GB
Core3566104000 4GB 0GB (Lite)
Core3566104032 4GB 32GB
Core3566-Kit-A/B
  1. CM4-IO-BASE-A x1
  5. 1PIN cable (4PCS) x1
Core3566-Kit-C/D
  1. CM4-to-Pi4-Adapter x1
  6. 1PIN cable (4PCS) x1
Core3566-Kit-E
  1. CM4-IO-BASE-A x1
  2. Core3566104032 x1
  5. IMX219-77 Camera x1
Core3566-Kit-F
  7. 1PIN cable (4PCS) x1
Core3566-Kit-G
  1. CM4-IO-BASE-A x1
Core3566-Kit-H
