Core3566104032 Module, CM4 to Pi4B Adapter Board + 4.3inch touch Display + Camera Kit, Rockchip RK3566 Quad-core Processor, Compatible With Raspberry Pi CM4
- Stock: In Stock
- Model: Core3566-Kit-F
- Weight: 0.42kg
- SKU: 25017
Processor | Quad-core Arm Cortex-A55 @1.8GHz |
Memory | Options for 2GB/4GB LPDDR4 SDRAM memory |
Storage | Options for 0GB (Lite) or 32GB eMMC Flash |
NPU | 0.8 TOPS @INT8 |
GPU | Arm Mali-G52 2EE |
Connectivity | Optional dual-band (2.4GHz/5.0GHz) IEEE 802.11b/g/n/ac wireless WiFi, Bluetooth 5.0, BLE, supports external antenna |
Supports IEEE 802.3 Gigabit Ethernet. | |
USB 2.0 × 1 | |
PCIe Gen 2 x 1 | |
28 GPIO signals | |
SD card interface (booted from eMMC first) | |
Video | HDMI interface (4Kp60 supported) |
2-lane MIPI DSI display interface × 2 | |
2-lane MIPI CSI camera interface × 2 | |
Multimedia | 4Kp60 H.264/H.265/VP9 (decode), 1080p60 H.264/H.265 (encode) |
Operating Voltage | 5V DC |
Operating Temp. | -10°C ~ 80°C ambient |
Dimensions | 55 × 40 × 4.7mm |
Kit | A | B | C | D | E | F | G | H |
Necessary accessories (UART module, 1PIN cables, USB cables, power supply) | √ | √ | √ | √ | √ | √ | √ | √ |
Core3566102032 | √ | √ | ||||||
Core3566104032 | √ | √ | √ | √ | √ | √ | ||
CM4-IO-BASE-A | √ | √ | √ | √ | ||||
CM4-to-Pi4-Adapter | √ | √ | √ | √ | ||||
HDMI to Micro HDMI Adapter | √ | √ | √ | √ | ||||
IMX219-77 Camera | √ | √ | ||||||
4.3inch DSI LCD | √ | √ | ||||||
8DP-CAPLCD | √ | √ |
- RK3566 Quad-core 64-bit Cortex-A55 processor, frequency up to 1.8GHz, with 22nm process, features low power consumption and high performance
- Integrated dual-core architecture ARM G52 GPU, high performance VPU and high efficiency NPU
- The GPU supports OpenGL ES3.2/2.0/1.1 and Vulkan1.1
- The VPU can support 4K 60fps H.265/H.264/VP9 video decoding and 1080P 60fps H.265/ H.264 video encoding
- The NPU with computing power of 0.8Tops supports one-click switching of mainstream frameworks like Caffe/TensorFlow
Model | Wireless | RAM | eMMC Flash |
Core3566 | 1 = Yes 0 = No | 02 = 2GB 04 = 4GB | 000 = 0GB (Lite) 032 = 32GB |
Example: Core3566104032, Core3566 module with onboard wireless, 4GB RAM, and 32GB eMMC Flash | |||
Core3566 | 1 | 04 | 032 |
Part Number | Wireless | RAM | eMMC Flash |
Core3566002000 | × | 2GB | 0GB (Lite) |
Core3566002032 | × | 2GB | 32GB |
Core3566004000 | × | 4GB | 0GB (Lite) |
Core3566004032 | × | 4GB | 32GB |
Core3566102000 | √ | 2GB | 0GB (Lite) |
Core3566102032 | √ | 2GB | 32GB |
Core3566104000 | √ | 4GB | 0GB (Lite) |
Core3566104032 | √ | 4GB | 32GB |
Core3566-Kit-A/B
- CM4-IO-BASE-A x1
- OPTIONS Core3566102032 / Core3566104032 x1
- CH343 USB UART Board (type C) with accessories x1
- USB Type-A to Type-C cable ~1m (2PCS) x1
- 1PIN cable (4PCS) x1
- OPTIONS 5V 3A power supply x1
Core3566-Kit-C/D
- CM4-to-Pi4-Adapter x1
- HDMI to Micro HDMI adapter x1
Core3566-Kit-E
- CM4-IO-BASE-A x1
- Core3566104032 x1
- 4.3inch DSI LCD with accessories x1
- IMX219-77 Camera x1
Core3566-Kit-F
- Core3566104032 x1
Core3566-Kit-G
- CM4-IO-BASE-A x1
- Core3566104032 x1
- 8DP-CAPLCD with accessories x1
Core3566-Kit-H
- Core3566104032 x1
- HDMI to Micro HDMI Adapter x1
