Luckfox Pico Pi Linux Micro Development Board, Based On Luckfox Core1106, 8GB eMMC, Supports Intelligent Encoding, Built-in Self-developed Third-generation ISP3.2, Up To 5MP Image Processing, Optional for Wireless / 4G Module
  • $48.99
  • Price Range $48.99 - $106.99
Luckfox Pico Pi
The Luckfox Pico Pi is a cost-effective Linux micro development board, based on the Luckfox Core1106 chip to provide a simple and efficient development platform for developers. Supports a variety of interfaces including MIPI CSI, GPIO, UART, SPI, I2C, USB, and an M.2 slot for 4G module, etc., which is ideal for a wide range of embedded applications.
Luckfox Pico Pi series, front view Luckfox Pico Pi series, features
Development Board Versions
Luckfox Pico Pi series, version options
Version Comparison
Model Luckfox Pico Pi A Luckfox Pico Pi B
Processor RV1106G3 RV1106G2
NPU 1TOPS 0.5TOPS
Memory 256MB DDR3L 128MB DDR3L
SIM7600G-H-M.2
The SIM7600G-H-M.2 is a LTE Cat 4 module which supports wireless communication modes of LTE-TDD, LTE-FDD, HSPA+, GSM, GPRS, and EDGE, etc. It adopts M.2 form factor and can be integrated into the Luckfox Pico Pi series
SIM7600G-H-M.2 4G module, front and back view
Wi-Fi 6 and Bluetooth module
Onboard 2.4GHz Wi-Fi 6 and Bluetooth 5.2/BLE Bluetooth Module, Providing Stable Connection And Efficient Transmission
Luckfox Pico Pi series, onboard Wi-Fi 6 and Bluetooth module
Reserved PoE Module Header
Luckfox Pico Pi series, onboard reserved PoE module header
* the PoE module is NOT included.
Onboard TF card slot
allows storage expansion via TF card
Luckfox Pico Pi series, onboard TF card slot
* Supports storage expansion only, does not support booting system from TF card.
Supports USB HUB Expansion
Flexible switching of USB-C / 4 × USB-A HOST ports via DIP switch
Luckfox Pico Pi series, onboard USB DIP switch
Onboard M.2 slot for 4G Module
The USB-A-4 port can be switched to 4G module M.2 slot via DIP switch, Supports SIM7600G-H-M.2 4G module
Luckfox Pico Pi series, onboard USB / M.2 slot DIP switch
Multiple Audio Interfaces
Onboard microphone + microphone expansion header + 3.5mm audio output jack, meets a variety of audio application scenarios
Luckfox Pico Pi series, onboard multiple audio interfaces
Luckfox Pico Pi series, onboard components
  1. Core1106
    RV1106G3 / RV1106G2 core module, optional for Wi-Fi / Bluetooth wireless module
  2. 4G NET LED
    for indicating the operating status of the 4G module
  3. USER-LED
    for indicating system operating status in the default image, programmable indicator
  4. 4G-RESET button
    for rebooting the 4G module
  5. RESET button
    for rebooting the Core1106 system
  6. BOOT button
  7. USB Type-C port
  8. RTC battery connector
  9. SIM card slot
  10. CSI camera interface
    MIPI CSI 2-lane
  1. 3.5mm audio jack
    Single channel audio output
  2. Microphone expansion header
  3. Onboard microphone
  4. USB-A Host ports
    Expands 4x USB-A ports via USB-HUB chip
  5. RJ45 100M Ethernet port
  6. DIP Switches
    Switch 1: for switching USB-C port and 4x USB-A ports
    Switch 2: for switching USB-A-4 port and 4G module M.2 slot
  7. 4G module M.2 slot
  8. PoE module header
  9. 40PIN GPIO header
    Compatible with some Raspberry Pi HATs
  10. TF card slot
Luckfox Pico Pi series, pin definition 1 Luckfox Pico Pi series, pin definition 2
Luckfox Pico Pi series, outline dimensions
Connectivity
Bluetooth Bluetooth 5.2/BLE (option)
Ethernet RJ45 100M (PoE opiton)
Wi-Fi Wi-Fi6
Audio Ouput 3.5mm audio jack
Camera Interface MIPI CSI 2-lane
GPIO 40PIN
M.2 4G module M.2 slot
Micro SD Slot
Microphone Onboard microphone
SIM Slot
USB USB-A Host x 4; USB Type-C × 1
Luckfox Pico Pi A / Luckfox Pico Pi B
  1. Luckfox Pico Pi A / Luckfox Pico Pi B x1
  2. 4G Module mounting screw x1
Luckfox Lyra Ultra PoE Kit
Luckfox Pico Pi A W / Luckfox Pico Pi B W
  1. Luckfox Pico Pi A W / Luckfox Pico Pi B W x1
  2. IPX 2.4G 2DB antenna x1
  3. 4G Module mounting screw x1
Luckfox Pico Pi A 4G Kit / Luckfox Pico Pi B 4G Kit
  2. SIM7600G-H-M.2 x1
  3. 4G antenna x1
  4. IPEX4 to SMA cable x1
  5. Screwdriver x1
  6. 4G Module mounting screw x1
Luckfox Pico Pi A W 4G Kit / Luckfox Pico Pi B W 4G Kit
  3. IPX 2.4G 2DB antenna x1
  4. 4G antenna x1
  5. IPEX4 to SMA cable x1
  6. Screwdriver x1
  7. 4G Module mounting screw x1
