Luckfox Aura High-Performance Linux Development Board, Rockchip RV1126B Quad-Core 1.6GHz Processor, 3 TOPS Computing Power, 4K Encoding And Decoding, Options For RAM And eMMC
  • $48.99
  • Price Range $48.99 - $143.99
Luckfox Aura
High-Performance Linux Development Board Based on Rockchip RV1126B
Luckfox Aura 200/400, front view Luckfox Aura 200/400, icon view
Version Options
Luckfox Aura 200/400, 0 / 64GB eMMC optional and 2/4 GB RAM optional
Processor Quad-core Arm [email protected]
RAM Options for 1GB /2GB / 4GB LPDDR4X RAM
Flash Memory Options for 0GB / 8GB / 64GB eMMC Flash
NPU 3 TOPS@INT8, supports INT4, INT8, INT16, FP16 mixed operation
ISP Supports 12MP cameras, supports multiple algorithm accelerators, including HDR, 3A, LSC, 3DNR, 2DNR, sharpening, defogging, fisheye correction, and gamma correction, integrates 8MP AI-ISP for enhanced spatial noise reduction and image enhancement effect
Video Decoding: 4K@30fps (H.265/HEVC, H.264/AVC)
Encoding: 4K@30fps (H.265/HEVC, H.264/AVC)
Storage TF card slot
Video Output 4-lane MIPI DSI (1920x1080@60fps) interface × 1
Video Input 4-lane MIPI CSI camera interface × 2
USB USB3.0 OTG Type-C port × 1
USB2.0 HOST Type-A port × 4
Audio Onboard microphone
3.5mm headphone / microphone jack
GPIO 40PIN header (compatible with some Raspberry Pi HATs)
System Buildroot, Debian
Power Input 5V DC
Others 2PIN SH1.0 RTC Batt header
SARADC × 7
Low Power quad-Core AIoT Processor
Equipped with high-performance RV1126B processor, integrated with quad-core Cortex-A53 processor, providing strong performance and high energy efficiency
Luckfox Aura 200/400, with quad-Core AIoT processor
Equipped with 3 TOPS computing power, easy to convert a variety of neural network models based on TensorFlow, MXNet, PyTorch, and Caffe frameworks, supports running large language models and Visual Language Models
Luckfox Aura 200/400, Object Recognition demo
Object Recognition
Luckfox Aura 200/400, Face Recognition demo
Face Recognition
Luckfox Aura 200/400, Vehicle Recognition demo
Vehicle Recognition
Luckfox Aura 200/400, Pedestrian Detection demo
Luckfox Aura 200/400, Text Recognition demo
Large Language Model
Luckfox Aura 200/400, Semantic Segmentation demo
Supports 4K encoding and decoding
Supports 4K@30fps H.264/H.265 hardware encoding and decoding capabilities,
easy to deal with HD video tasks
Luckfox Aura 200/400, supports 4K encoding and decoding
MIPI DSI 4-lane Interface
Powerful performance, easy to drive large screens
Luckfox Aura 200/400, MIPI DSI 4-lane Interface Connection Demonstration
* Supports up to 1920 × 1080@60Hz resolution.
for reference only, the 13.3inch DSI LCD is not included.
MIPI CSI 4-lane dual camera interfaces
Suitable for AI vision applications such as visual robotics,
depth vision, and stereo vision
Luckfox Aura 200/400, Demonstrated two cameras connected
*for reference only, please refer to the package content for detailed part list.
Wi-Fi 6 and Bluetooth module
Onboard 2.4GHz/5GHz Wi-Fi 6 and Bluetooth 5.4/BLE Bluetooth Module,
Providing Stable Connection And Efficient Transmission
Luckfox Aura 200/400, Onboard 2.4GHz/5GHz Wi-Fi 6 and Bluetooth 5.4/BLE Bluetooth Module, Providing Stable Connection And Efficient Transmission
Gigabit PoE Ethernet port
Supports 10M/100M/1000M Ethernet port to meet file transfer and video streaming needs, with reserved PoE module header for more flexible power supply
Luckfox Aura 200/400, supports Gigabit PoE Ethernet port
Audio interfaces
Onboard Microphone + 3.5mm Headphone / Microphone Jack, meets a variety of audio application scenarios
Luckfox Aura 200/400, Onboard Microphone + 3.5mm Headphone / Microphone Jack, meets a variety of audio application scenarios
Application Examples
Luckfox Aura 200/400, application examples
Luckfox Aura 200/400, Pin definition Luckfox Aura 200/400, Pin definition
  1. RV1126B
    built-in quad-core ARM Cortex-A53
  2. eMMC (options for 0GB / 8GB / 64GB)
  3. Wi-Fi / BT module
    2.4GHz / 5GHz Wi-Fi 6 + BT 5.4 / BLE module
  4. Wi-Fi / BT module antenna connectors
  5. DSI display interface
  6. USER-LED
    for indicating system operating status in the default image
  7. POWER-LED
    for indicating power supply status
  8. USB-PWR
    for 5V DC power supply
  9. RESET button
  10. BOOT button
  11. USB3.0 OTG Type-C port
    for programming, emulating USB devices, or connecting USB peripherals
  1. RTC header
  2. Onboard microphone
  3. DEBUG header
  4. 3.5mm headphone / microphone jack
    supports audio capture or output
  5. CSI-0 camera interface
    enabled by default
  6. CSI-1 camera interface
  7. PoE module header
  8. Gigabit RJ45 Ethernet port with LED indicators (PoE-enabled)
    supports power supply via PoE switch with network cable
  9. USB2.0 HOST Type-A ports
    expands 4-ch Type-A ports via USB-HUB chip
  10. LPDDR4X (options for 1GB / 2GB / 4GB)
  11. 40PIN GPIO header
  12. TF card slot
  13. SARADC interface
Luckfox Aura 200/400, outline dimensions
Connectivity
Bluetooth Bluetooth 5.4/BLE
Ethernet RJ45 10/100/1000M (PoE)
Wi-Fi Wi-Fi6
Memory and Storage
eMMC 0GB / 64GB
Memory 2GB / 4GB LPDDR4X
SOC Features
NPU 3 TOPS@INT8
Audio Ouput 3.5mm audio jack
Camera Interface MIPI CSI 4-lane x 2
Display Interface MIPI DSI 4-lane
GPIO 40PIN
Micro SD Slot
Microphone Onboard microphone
USB USB2.0 Type-A x 4; USB3.0 Type-C x 1
Luckfox-Aura-01000/02000/04000
  1. OPTIONS Luckfox-Aura-01000/02000/04000 x1
  2. SH1.0 3PIN cable ~100mm x2
  3. IPEX 4 to SMA cable x2
  4. 6DB antenna ~17cm x2
  5. USB Type-A to Type-C cable ~1m x1
1 Luckfox-Aura-02000
2
3
4
5
Luckfox-Aura-01008/02064/04064
  1. OPTIONS Luckfox-Aura-01008/02064/04064 x1
1 Luckfox-Aura-02064
2
3
4
5
