Luckfox CM5 IO Board For Compute Module 5, Dual HDMI Ports, Dual USB3.0 Ports, PoE Gigabit Ethernet RJ45 connector, PCIe M.2 Slot, for all Variants of CM5
  • Model:Luckfox CM5 IO Board
  • SKU:30709
  • $16.99
    In Stock
suitable for evaluating the Raspberry Pi CM5 or being integrated into end products
IO Base Board for all Compute Module 5 Variants
Luckfox CM5 IO Board For Compute Module 5, front view
The Luckfox CM5 IO Board is a companion board for Raspberry Pi Compute Module 5. It is designed for use both as a development system for Compute Module 5 and as an embedded board integrated into end products.
The IO board is designed to allow you to create systems quickly using off-the-shelf parts such as HATs and PCIe modules. The major user connectors are located along one side to make enclosures simple.
CM5 socket Suitable for all variants of Compute Module 5
Network Gigabit Ethernet RJ45 port
Supports PoE function, onboard PoE header, an external PoE module (NOT included) is required
Connectors Raspberry Pi 40PIN GPIO header
M.2 M-Key PCIe socket, compatible with 2230, 2242, 2260 and 2280 form factors
USB 2 x USB3.2 Gen1 connectors
1 x Type-C port for updating Compute module 5
MIPI 2 x 4-lane MIPI DSI/CSI-2 connectors
Video 2 x HDMI ports with 4K support
RTC CR / ML2032 battery socket
Storage socket MicroSD card socket for Compute Module 5 Lite (without eMMC) variants
Fan connector 5V, JST-SH PWM 4PIN connector
Power input 5V @5A via Type-C port, the same standard as the Raspberry Pi 5
Dimensions 160 × 90mm
Supports M.2 NVMe Solid State Drive
Faster reading/writing speed compared to the Micro SD slot of Raspberry Pi, greatly improving reading/writing efficiency of the system or files, support booting Raspberry Pi from NVMe Solid State Drive
Luckfox CM5 IO Board For Compute Module 5, supports installing M.2 NVMe Solid State Drive
* for reference only, the Solid State Drive is NOT included
Compatible with multiple M.2 Drive sizes
supports 2280 / 2260 / 2242 / 2230 form factors
Luckfox CM5 IO Board For Compute Module 5, compatible With 2230 / 2242 / 2260 / 2280 Size M.2 Solid State Drive
NVMe Drive Slot Support
Luckfox CM5 IO Board For Compute Module 5, NVMe Drive slot support
Note: Only supports the NVMe Protocol Solid State Drives.
Interface introduction
Luckfox CM5 IO Board For Compute Module 5, interfaces introduction
Product show
Luckfox CM5 IO Board For Compute Module 5, product show, connecting with LCD and cooling fan
* for reference only, please refer to the Package Content for detailed part list
Luckfox CM5 IO Board For Compute Module 5, outline dimensions
Connectivity
Ethernet PoE RJ45 100M
Camera Interface MIPI
Display Interface MIPI DSI × 2; HDMI × 2
GPIO Raspberry Pi 40PIN GPIO
M.2 M.2 M
Micro SD Slot
USB USB3.2 Gen1 × 2
Others
Power input 5V@5A
  1. Luckfox CM5 IO Board x1
  2. Screws pack x1
  3. SSD mounting screw x1
