Luckfox Lyra Plus RK3506G2 Linux Micro Development Board, Integrates Tripe-core ARM Cortex-A7 and ARM Cortex-M0 Processors, With Ethernet Port
  • $30.99
  • Price Range $30.99 - $90.99
Luckfox Lyra Plus RK3506G2 Linux Micro Development Board, front view Luckfox Lyra Plus RK3506G2 Linux Micro Development Board, features
Processor Triple-Core Arm Cortex-A7 (1.2Ghz) + Arm Cortex-M0
Memory 128MB DDR3L
USB USB OTG2.0 × 2
Display MIPI DSI 2-lane
GPIO 24 × Rockchip Matrix IO pins
Ethernet port 10/100M Ethernet controller
Default Storage SPI NAND FLASH (256MB)
Version options
Luckfox Lyra Plus RK3506G2 Linux Micro Development Board, version options
Kit Selection
Luckfox Lyra Plus RK3506G2 Linux Micro Development Board, adopts RK3506G2 chip
  • Triple-Core ARM Cortex-A7 32-bit core, with integrated VFP to support single- and double-precision floating-point operations
  • Built-in ARM Cortex-M0 MCU design, supports SMP and AMP configuration
  • Built-in 128MB DDR3L for multi-core applications
  • The low-speed interfaces adopt Rockchip Matrix IO design, which allows rich function signals to share the limited chip pins, making peripheral circuit adaptation more flexible
  • Built-in audio and video codec, supports multiple audio inputs and outputs, providing high-quality audio playback and recording functions
Easier to develop
Integrates TF card slot, DSI interface, USB connector and Ethernet port
Luckfox Lyra Plus RK3506G2 Linux Micro Development Board, integrates TF card slot, DSI interface and USB connector and Ethernet port
MIPI DSI 2-lane interface
Compact size, powerful performance, easy to drive large screens
Luckfox Lyra Plus RK3506G2 Linux Micro Development Board, onboard MIPI DSI 2-lane interface
* for reference only, please refer to the Package Content for the detailed part list.
Supports up to 1280 × 800 @ 60Hz resolution.
The Rockchip Matrix IO supports 98 multiplexed functions and allows flexible pinout configuration
Luckfox Lyra Plus RK3506G2 Linux Micro Development Board, adopts Rockchip Matrix IO design
SLC NAND FLASH
onboard 256MB SLC NAND FLASH, provides a better user experience
Luckfox Lyra Plus RK3506G2 Linux Micro Development Board, onboard 256MB SLC NAND FLASH
Luckfox Lyra Plus RK3506G2 Linux Micro Development Board, suitable for more application examples
Luckfox Lyra Plus RK3506G2 Linux Micro Development Board, pin definition
Luckfox Lyra Plus RK3506G2 Linux Micro Development Board, onboard components
  1. USB Type-C connector
  2. ACT-LED
  3. BOOT button
  4. RESET button
  5. USB MX1.25 4P connector
    can be converted to USB Type-A port via an adapter cable
  6. TF card slot
  1. RK3506G2
    Multi-core heterogeneous SoC with built-in Triple-Core ARM Cortex-A7 + ARM Cortex-M0
  2. DSI display interface
    MIPI DSI 2-lane
  3. RJ45 Ethernet port
  4. W25N02KV
  5. CH182H2
    100 Mbps Ethernet PHY chip
Product Show
Luckfox Lyra Plus RK3506G2 Linux Micro Development Board, product show
Luckfox Lyra Plus RK3506G2 Linux Micro Development Board, outline dimensions
Resources & Services
Connectivity
Ethernet RJ45 100M
Memory and Storage
Flash 256MB
Memory 128MB DDR3L(OPTIONS)
SOC Features
Processor [email protected]
Display Interface MIPI DSI 2-lane
GPIO 24-Pin
USB USB OTG2.0
Luckfox Lyra Plus
Luckfox Lyra Plus x1
Luckfox Lyra Plus
Luckfox Lyra Plus M
Luckfox Lyra Plus with pre-soldered header x1
Luckfox Lyra Plus M
Luckfox Lyra Plus LCD Kit A
  1. 10.1-DSI-TOUCH-A ×1
  2. MX 1.25 2PIN to 2.54 3PIN cable x1
  3. Luckfox Lyra Plus ×1
  4. MX 1.25 2PIN to 4PIN cable x1
  5. MIPI-DSI-Cable-12cm x1
  6. FFC 22PIN cable ~200mm (opposite sides) x2
Luckfox Lyra Plus M
