Luckfox Lyra Pi Linux Micro Development Board, Based On Luckfox Core3506 Core Board, Integrates Triple-core ARM Cortex-A7 and ARM Cortex-M0 Processors
  • $27.99
  • Price Range $27.99 - $93.99
Luckfox Lyra Pi
The Luckfox Lyra Pi is a cost-effective Linux micro development board, based on the Luckfox Core3506 chip to provide a simple and efficient development platform for developers. Onboard multiple high-speed interfaces including MIPI DSI, RMII, SDIO, USB, etc. to meet various application scenarios. The low-speed interfaces utilize Rockchip Matrix IO design which supports multiplexing 98 function signals on GPIO pins, allowing for flexible configuration of interfaces like PWM, UART, I2C, SPI, and I2S for quick development and debugging.
Luckfox Lyra Pi series, front view Luckfox Lyra Pi series, features
Development Board Versions
Luckfox Lyra Pi series, version options
Version Comparison
Model PI A PI B PI A W PI B W
Processor Triple-core Arm Cortex-A7 (1.2Ghz) + Arm Cortex-M0
Memory 512MB DDR3L
USB Original USB OTG2.0 × 1,
Extended USB HOST2.0 × 3 via HUB
Display MIPI DSI 2-lane
GPIO 23 × Rockchip Matrix IO pins + 5 × GPIO pins
Default Storage 8GB eMMC TF card (NOT included) 8GB eMMC TF card (NOT included)
Wireless - Onboard 2.4GHz WiFi 6 / Bluetooth 5.2 / BLE
SIM7600G-H-M.2
The SIM7600G-H-M.2 is a LTE Cat 4 module which supports wireless communication modes of LTE-TDD, LTE-FDD, HSPA+, GSM, GPRS, and EDGE, etc. It adopts M.2 form factor and can be integrated into the Luckfox Lyra Pi series
SIM7600G-H-M.2 4G module, front and back view
Wi-Fi 6 and Bluetooth module
Onboard 2.4GHz Wi-Fi 6 and Bluetooth 5.2/BLE Bluetooth Module, Providing Stable Connection And Efficient Transmission
Luckfox Lyra Pi series, onboard Wi-Fi 6 and Bluetooth module
Reserved PoE Module Header
Luckfox Lyra Pi series, onboard reserved PoE module header
* the PoE module is NOT included.
USB HUB Expansion
Expands to 2 × USB-A HOST ports and an MX1.25 USB header via USB HUB
Luckfox Lyra Pi series, onboard 2 × USB-A HOST ports
Onboard M.2 slot for 4G Module
The USB signal of the MX1.25 USB port can be switched to 4G module M.2 slot via DIP switch, only compatible with the SIM7600G-H-M.2 4G module
Luckfox Lyra Pi series, onboard USB / M.2 slot DIP switch Luckfox Lyra Pi series, onboard USB / M.2 slot DIP switch
* for reference only, please refer to the part list for detailed package content.
Audio Interface
Onboard 3.5mm headphone/microphone audio jack, meets a variety of audio application scenarios
Luckfox Lyra Pi series, onboard multiple audio interfaces
MIPI DSI 2-lane interface
Compact size, powerful performance, easy to drive large screens
Luckfox Lyra Pi series, onboard MIPI DSI 2-lane interface
Supports up to 1280 × 1280 @ 60Hz resolution. The resolution of the screen in the picture is 800 × 1280.
The Rockchip Matrix IO supports 98 multiplexed functions and allows flexible pinout configuration
Luckfox Lyra Pi series, adopts Rockchip Matrix IO design
Luckfox Lyra Pi series, suitable for more application examples
Luckfox Lyra Pi series, pin definition
Luckfox Lyra Pi series, onboard components
  1. Core3506
    RK3506B core module, optional for eMMC
  2. USB Type-C OTG0 port
  3. BOOT button
  4. RESET button
    for rebooting the Core3506 system
  5. 4G-RESET button
    for rebooting the 4G module
  6. 4G NET LED
    for indicating the operating status of the 4G module
  7. USER-LED
    for indicating system operating status in the default image
  8. 3.5mm headphone/microphone jack
    Supports single-channel audio capture or output
  9. MX1.25 4P header
    Supports conversion to USB-A HOST interface or for LCD screen power supply
  1. USB-A HOST ports
    Expands 2x USB-A ports via USB-HUB chip
  2. RJ45 100M Ethernet port
  3. RJ45 100M Ethernet port (with PoE support)
    Supports power supply via PoE switch with network cable
  4. PoE module header
  5. 40PIN GPIO header
    Compatible with some Raspberry Pi HATs
  6. WIFI/Bluetooth module (optional)
    2.4G WiFi 6 / BT5.2 / BLE Bluetooth module
  7. Antenna connector
  8. DSI interface
    MIPI DSI 2-lane
  9. 4G module M.2 slot
    Supports SIM7600G-H-M.2 4G module
  10. TF card slot
    for Lyra Pi B versions only
  11. SIM card slot
Luckfox Lyra Pi series, outline dimensions
Connectivity
Bluetooth Bluetooth 5.2/BLE (option)
Ethernet RJ45 100M
Wi-Fi Wi-Fi6 (option)
Memory and Storage
eMMC 8GB (option)
Memory 512MB DDR3L
SOC Features
Processor [email protected]
Audio Ouput 3.5mm audio jack
Display Interface MIPI CSI 2-lane
M.2 4G module M.2 slot
Micro SD Slot (option)
SIM Slot
USB Original USB OTG2.0 × 1, Extended USB HOST2.0 × 3 via HUB
Luckfox Lyra Pi A
  1. Luckfox Lyra Pi A x1
  2. 4G Module mounting screw x1
Luckfox Lyra Pi A
Luckfox Lyra Pi B
  1. Luckfox Lyra Pi B x1
Luckfox Lyra Pi B
Luckfox Lyra Pi A W
  1. Luckfox Lyra Pi A W x1
  2. IPX 2.4G 2DB antenna x1
  3. 4G Module mounting screw x1
Luckfox Lyra Pi A W
Luckfox Lyra Pi B W
  1. Luckfox Lyra Pi B W x1
Luckfox Lyra Pi B W
Luckfox Lyra Pi A 4G Kit
  2. SIM7600G-H-M.2 x1
  3. 4G antenna x1
  4. IPEX4 to SMA cable x1
  5. Screwdriver x1
  6. 4G Module mounting screw x1
Luckfox Lyra Pi A
Luckfox Lyra Pi B 4G Kit
  3. 4G antenna x1
  5. Screwdriver x1
Luckfox Lyra Pi B
Luckfox Lyra Pi A W 4G Kit
  3. 4G antenna x1
  4. IPX 2.4G 2DB antenna x1
  5. IPEX4 to SMA cable x1
  6. Screwdriver x1
  7. 4G Module mounting screw x1
Luckfox Lyra Pi A W
Luckfox Lyra Pi B W 4G Kit
  3. 4G antenna x1
  6. Screwdriver x1
Luckfox Lyra Pi B W
