Luckfox Pico WebBee RV1103 Linux Micro Development Board, Integrates Arm Cortex-A7/RISC-V MCU/PHY, Onboard Ethernet Port, With ABS Protective Case
$13.99
Luckfox Pico WebBee
Cost-effective Linux micro development board based on Rockchip RV1103 chip
Features At A Glance
This product is a cost-effective Linux micro development board based on the Rockchip RV1103 chip, which is designed for developers with a simple and convenient development platform.
- Onboard USB Type-A port, easy access to the PC, plug and play, to help developers get started quickly in development and debugging
- Equipped with 10/100Mbps Ethernet port, ensures stable and smooth network connection
- Customized ABS protective case, robust and durable, suitable for various application scenarios, to meet the diverse project needs of developers
CPU | RV1103 G1 |
Processor | Cortex-A7 1.2GHz + RISC-V |
RAM | 64MB DDR2 |
USB | USB 2.0 Host/Device |
Ethernet port | 10/100M Ethernet controller and embedded PHY |
Default Storage | SPI NAND FLASH (128MB) |
Storage Extension | Supports booting or storage expansion with a TF card |
Integrates CPU, PHY, DDR
- Single-core ARM Cortex-A7 32-bit core with integrated NEON and FPU
- Built-in 16-bit DRAM DDR2, which is capable of sustaining demanding memory bandwidths
- Built-in MAC 10/100M Ethernet controller and PHY for daily network requirement
Easier Development with Case Protection
SLC NAND FLASH
provides A better user experience for you
Application Example
* for reference only, please refer to the Package Content for detailed part list
Suitable for more application scenarios
Lightweight Web Server
USB Script Tool
Smart Home Device
Development Resources
Complete software and hardware documentation and an active community to help with secondary development
- USB Type-A port
for power supply, program burning, debugging and network equipment simulating - TF card slot
- RV1103
ARM Cortex-A7 processor SoC - Ethernet transformer
- RJ45 Ethernet port
- ACT-LED
- Power indicator
- BOOT button
Press it when powering on to enter download mode - W25N01KV
128MB SLC NAND FLASH - Hidden BOOT button
Luckfox-WebBee x1
Connectivity | |
Ethernet | RJ45 100M |
Memory and Storage | |
Flash | 256MB |
Memory | 128MB DDR2 |
SOC Features | |
ISP | 5MP@30fps |
Processor | Single-core@1.2GHz |
Interfaces & Peripherals | |
