Luckfox Pico WebBee RV1103 Linux Micro Development Board, Integrates Arm Cortex-A7/RISC-V MCU/PHY, Onboard Ethernet Port, With ABS Protective Case
  • Model:Luckfox-WebBee
  • SKU:29417
  • $149.00
    In Stock
Luckfox Pico WebBee
Cost-effective Linux micro development board based on Rockchip RV1103 chip
Luckfox Pico WebBee Development Board, front view Luckfox Pico WebBee Development Board, features
Features At A Glance
This product is a cost-effective Linux micro development board based on the Rockchip RV1103 chip, which is designed for developers with a simple and convenient development platform.
  • Onboard USB Type-A port, easy access to the PC, plug and play, to help developers get started quickly in development and debugging
  • Equipped with 10/100Mbps Ethernet port, ensures stable and smooth network connection
  • Customized ABS protective case, robust and durable, suitable for various application scenarios, to meet the diverse project needs of developers
CPU RV1103 G1
Processor Cortex-A7 1.2GHz + RISC-V
RAM 64MB DDR2
USB USB 2.0 Host/Device
Ethernet port 10/100M Ethernet controller and embedded PHY
Default Storage SPI NAND FLASH (128MB)
Storage Extension Supports booting or storage expansion with a TF card
Integrates CPU, PHY, DDR
Luckfox Pico WebBee Development Board, powerful performance processor
  • Built-in 16-bit DRAM DDR2, which is capable of sustaining demanding memory bandwidths
  • Built-in MAC 10/100M Ethernet controller and PHY for daily network requirement
Easier Development with Case Protection
Luckfox Pico WebBee Development Board, with case protection
SLC NAND FLASH
provides A better user experience for you
Luckfox Pico WebBee Development Board, onboard SLC NAND FLASH
Application Example
Luckfox Pico WebBee Development Board, application example
* for reference only, please refer to the Package Content for detailed part list
Suitable for more application scenarios
Luckfox Pico WebBee Development Board, application examples on Lightweight Web Server
Luckfox Pico WebBee Development Board, application examples on USB Script Tool
USB Script Tool
Luckfox Pico WebBee Development Board, application examples on Smart Home Device
Smart Home Device
Development Resources
Complete software and hardware documentation and an active community to help with secondary development
Luckfox Pico WebBee Development Board, comes with development resources
Luckfox Pico WebBee Development Board, onboard components
  1. USB Type-A port
    for power supply, program burning, debugging and network equipment simulating
  2. TF card slot
  3. RV1103
    ARM Cortex-A7 processor SoC
  4. Ethernet transformer
  5. RJ45 Ethernet port
  1. ACT-LED
  2. Power indicator
  3. BOOT button
  4. W25N01KV
    128MB SLC NAND FLASH
  5. Hidden BOOT button
Luckfox Pico WebBee Development Board, outline dimensions
Connectivity
Ethernet RJ45 100M
Memory and Storage
Flash 256MB
Memory 128MB DDR2
SOC Features
ISP 5MP@30fps
Processor [email protected]
Luckfox-WebBee x1
