Luckfox Core1106 Smart 86 Box Development Board, RV1106G2/RV1106G3 Processor, 0.5/1TOPS, 128MB/256MB DDR3L
  • $62.99
  • Price Range $62.99 - $72.99
Based on Luckfox Core1106 series module, supports secondary development
Enable Smart Living & Industrial IoT For Scenario-Based Control
Luckfox Pico 86 Panel series, front view Background blue, screen displays current temperature, humidity, time, date, wifi, Bluetooth Luckfox Pico 86 Panel series, features ARM Cortex-A7 processor, 128MB/256MB DDR3L RAM, 720x720 resolution display, 5-point touch capability, RS485 communication, and dual-channel relay control
Development Board Versions
Luckfox Pico 86 Panel series, version options 0208/0408/1208/1408: optional WiFi and Bluetooth Modules
Model 0208 1208 0408 1408
Processor RV1106G2 RV1106G3
NPU 0.5TOPS 1TOPS
Memory 128MB DDR3L 256MB DDR3L
Wireless module - Wi-Fi 6 & Bluetooth 5.2/BLE - Wi-Fi 6 & Bluetooth 5.2/BLE
4inch IPS Touch Display Introduction
170° wide viewing angle
Excellent display performance, high contrast ratio, Wide viewing angles
Luckfox Pico 86 Panel series, 170° ultra-wide viewing angle
Capacitive 5-point Touch Screen
Supports flexible and responsive touch operation to make development more convenient
Luckfox Pico 86 Panel series, 5-point capacitive touch
* for reference only, the base case in the picture is NOT included
LCD Specifications
Model 720×720 4inch IPS Touch Display
Resolution 720×720
Communication Interface RGB666
Display SIZE 4"
Display Panel IPS
Touch Type Capacitive
Touch Chip GT911
Brightness 400cd/m²
Contrast ratio 1000:1
Viewing Angle 170°
Outline Dimension 84.0×84.0mm (H×V)
Display area 71.93×71.93mm (H×V)
Pixel pitch 0.0999×0.0999mm (H×V)
DISPLAY COLOUR GAMUT 68% NTSC
Development Board Introduction
Luckfox Pico 86 Panel series, integrates RV1106
  • Built-in Rockchip self-developed 4th generation NPU, features high computing precision and supports int4, int8, and int16 hybrid quantization. The int8 computing power of RV1106G3 is 1TOPS, and RV1106G2 is 0.5TOPS
  • Features powerful encoding performance, supports intelligent encoding mode and adaptive stream saving according to the scene, saves more than 50% bit rate of the conventional CBR mode so that the images from camera are high-definition with smaller size
  • Built-in 16-bit DRAM DDR3L, which is capable of sustaining demanding memory bandwidths
WiFi 6 and Bluetooth module
Optional for 2.4GHz WiFi 6 and Bluetooth 5.2/BLE Bluetooth Module, providing Stable Connection And Efficient Transmission
Luckfox Pico 86 Panel series, optional  WiFi 6 and Bluetooth module
* WiFi 6 / Bluetooth module is only available in Luckfox-Pico-86-Panel-1208 / 1408
Audio input / playback
Onboard microphone and speaker to meet the needs of daily audio applications
Luckfox Pico 86 Panel series, onboard microphone and speaker
Onboard RS485 interface
Supports Automatic data transmission and reception, built-in power isolation, digital isolation, TVS and other protections
Luckfox Pico 86 Panel series, onboard power isolation, digital isolator chip, RS485 interface
2-Channel Relay
Onboard Optocoupler isolation, prevents the relay from being interfered by high-voltage circuit
Luckfox Pico 86 Panel series, onboard  relay indicator light, optocoupler isolation, relay
100M RJ45 Ethernet Port
Supports 10/100M wired network communication
Luckfox Pico 86 Panel series, onboard 100M RJ45 Ethernet Port
* When connecting the network cable, the depth of the 86-type back box should be considered. A short-body RJ45 connector cable is recommended.
Installation diagram
Designed with standard 86 dimensions and a modular structure for easy installation
Luckfox Pico 86 Panel series, installation diagram of 86-Type back box, relay & comm module, and display module
* the 86-type back box and screws are NOT included
It is recommended to use an 86-type back box with a depth of 33mm or more
If you need to use RJ45 interface, the back box depth of ≥35mm is required
If you need to use a 33~35mm back box, a short-body RJ45 connector cable is recommended
Application Scenarios
Luckfox Pico 86 Panel series, application scenarios of smart switch, human-machine interface, smart home terminal
Luckfox Pico 86 Panel series, onboard components
  1. Core1106
    RV1106G3 / RV1106G2 core module
    optional for Wi-Fi / Bluetooth wireless module
  2. ACT_LED
    for indicating system operation status in the default image
  3. USB Type-C connector
  4. BOOT button
  1. RESET button
    for rebooting the system
  2. Onboard microphone
  3. RGB LCD interface
  4. RTC button cell holder
  5. Audio interface
    MX1.25 2P connector, supports 8Ω 1W speaker
  6. Serial port Debug interface
    SH1.0 3P connector
  7. 14pin multi-function pin
    for connecting 86 Panel Bottom Board
  1. RJ45 100M Ethernet port
  2. Relay indicators
  3. Power isolation module
  4. Digital isolator
  5. Optocoupler isolation
  1. Relay
  2. Relay screw terminal
  3. RS485 screw terminal
  4. Power screw terminal
    wide voltage range input: DC 6V to 30V
Luckfox Pico 86 Panel series, outline dimensions
Connectivity
Bluetooth Bluetooth 5.2/BLE
Wi-Fi Wi-Fi 6
Memory and Storage
Memory 128MB / 256MB
SOC Features
Processor RV1106G2 / RV1106G3
Display
Size 4 inch
Resolution 720 × 720
Display Panel IPS
Viewing Angle 170°
Brightness 400cd/m²
Contrast Ratio 1000:1
Display Colour Gamut 68% NTSC
Pixel Pitch (H×V) 0.0999×0.0999 (mm)
Touch
Touch Chip GT911
Others
Storage Temp. 0.5TOPS / 1TOPS
  1. Luckfox-Pico-86-Panel x1
Luckfox CM5 IO Board
