Luckfox Nova Micro Development Board, Based On Rockchip RK3308B, 8GB eMMC, Integrated High-Performance Audio Codec, Optional for Wireless / PoE Module
The Luckfox Nova is an embedded development board based on the Rockchip RK3308B chip. The Rockchip RK3308B is a high-performance processor designed for smart voice interaction, audio input/output processing, and digital multimedia applications. Its core architecture adopts 64-bit quad-core ARM Cortex-A35, with a maximum clock speed of 1.3GHz, providing powerful computing capability to handle complex embedded tasks with ease.
- ARM quad-core 64-bit Cortex-A35 at 1.3GHz, with integrated high-performance Audio Codec and Voice Activity Detection (VAD) modules
- Built-in Audio Codec with up to 8-channel microphone inputs for easy development of multi-microphone array applications
- Adapting 2 × 26PIN GPIO headers, supports UART, SPI, I2C and other peripheral controls
- Onboard 8GB eMMC + TF card expansion (supports SDIO 3.0 protocol), to meet the needs of large-capacity data storage
- Onboard 512MB DDR3 memory for smooth multi-tasking operation
Onboard 2.4GHz Wi-Fi 6 and Bluetooth 5.2/BLE Bluetooth Module, Providing Stable Connection And Efficient Transmission
Provides Both Network Connection And Power Supply for Luckfox Nova board In Only One Ethernet Cable
* the PoE module is optional, and the switch in the picture above is NOT included.
allows storage expansion via TF card
Onboard microphone + speaker header
- USB Type-C port
for power supply and program burning - USER-LED
for indicating system operating status in the default image, programmable indicator - BOOT button
Press it when powering on or resetting to enter download mode - RESET button
- GPIO headers
- Onboard microphone
- Antenna connector
(for wireless version only) - WIFI/Bluetooth module
2.4G WiFi 6 / BT5.2 / BLE Bluetooth module (for wireless version only) - Type-A port
- RJ45 100M Ethernet port
- Speaker header
MX1.25 2P connector, supports 8Ω 2W speaker - Analog / Digital audio interface
- 512MB DDR3
- RK3308B
- PoE module / external power supply header
for connecting external 5V power supply or PoE module power supply - PoE module header
- TF card slot
- 8GB eMMC
Luckfox Nova
- Luckfox Nova x1
- USB Type-A to Type-C cable ~1m x1
Luckfox Nova W
- Luckfox Nova W x1
- IPEX4 to SMA cable x1
- 6DB antenna ~17cm x1
Luckfox Nova PoE Kit
- Luckfox Nova x1
- Luckfox PoE module x1
- Screws pack x1
Luckfox Nova W PoE Kit
- Luckfox Nova W x1
- Screws pack x1
- 6DB antenna ~17cm ~17cm x1
Connectivity | |
Bluetooth | Bluetooth 5.2/BLE |
Ethernet | RJ45 100M (PoE Options) |
Wi-Fi | Wi-Fi 6 |
Memory and Storage | |
eMMC | 8GB |
Memory | 512MB DDR3 |
SOC Features | |
Processor | Quad-Core@1.3GHz |
Interfaces & Peripherals | |
Audio Ouput | MX1.25 2P Connector |
Camera Interface | MIPI CSI 2-lane |
GPIO | 2 × 26PIN |
Micro SD | Slot |
Microphone | Onboard microphone |
USB | USB Type-A; USB Type-C |
