Luckfox Lyra Zero W Micro Linux Development Board Based On RK3506B Chip, Integrated With Triple-core Arm Cortex-A7 And Arm Cortex-M0 Processors
$16.99
  • Model: Luckfox Lyra Zero W
  • Weight: 0.01kg
  • SKU: 30983
  • Battery: Not included
Luckfox Lyra Zero W
Luckfox Lyra Zero W is a Linux micro development board powered by the Rockchip RK3506B to provide a simple and efficient development platform for developers. Onboard multiple high-speed interfaces including MIPI DSI, SDMMC, USB, etc. to meet various application scenarios. The low-speed interfaces utilize Rockchip Matrix IO design which supports multiplexing 98 function signals on GPIO pins, allows for flexible configuration of interfaces like PWM, UART, I2C, SPI, and I2S for quick development and debugging. Integrated wireless communication module, suitable for IoT communication scenarios such as smart home and industrial control.
Luckfox Lyra Zero W, front view Luckfox Lyra Zero W, features
ModelLuckfox Lyra Zero W
ProcessorTriple-core Arm Cortex-A7 (1.2GHz) + Arm Cortex-M0
MemoryOnboard 512MB DDR3L
USBOriginal USB OTG 2.0 × 1
HUB expanded USB HOST 2.0 × 2
Display InterfaceMIPI DSI 2-lane
GPIO28 × Rockchip Matrix IO pins
Default StorageSPI NAND FLASH (256MB)
Wireless communicationOnboard 2.4GHz Wi-Fi 6 / Bluetooth 5.2 / BLE
Luckfox Lyra Zero W, Highly integrated and powerful performance
  • Triple-core ARM Cortex-A7 32-bit core, with integrated VFP to support single-precision and double-precision floating-point operations
  • Built-in ARM Cortex-M0 MCU design, supports SMP and AMP configuration
  • Supports DDR3L memory interface expansion, meeting various expansion needs
  • The low-speed interfaces adopt Rockchip Matrix IO design, which allows rich function signals to share the limited chip pins, making peripheral circuit adaptation more flexible
  • Supports multiple audio inputs and outputs, providing high-quality audio playback and recording functions
Easier to develop
Integrated TF card slot, DSI interface, USB-C HOST port, and MX1.25 USB HOST header
Luckfox Lyra Zero W, Integrated TF card slot, DSI interface, USB-C HOST port, and MX1.25 USB HOST port
WiFi 6 and Bluetooth module
Onboard 2.4GHz WiFi 6 and Bluetooth 5.2/BLE Module, Providing Stable Connection And Efficient Transmission
Luckfox Lyra Zero W, onboard WiFi 6 and Bluetooth module
Antenna Switching
Flexible Switching Between External Antenna and Onboard Antenna to meet more usage scenarios
Luckfox Lyra Zero W, Antenna Switching
MIPI DSI 2-lane interface
Compact size, powerful performance, easy to drive large screens
Luckfox Lyra Zero W, onboard MIPI DSI 2-lane interface
* for reference only, please refer to the Package Content for the detailed part list.
The display resolution of the above LCD is 800 × 1280, Supports up to 1280 × 1280 @ 60Hz resolution.
Rockchip Matrix IO Design
The Rockchip Matrix IO supports 98 multiplexed functions and allows flexible pinout configuration
Luckfox Lyra Zero W, Rockchip Matrix IO Design
Suitable for more application scenarios
Luckfox Lyra Zero W, product show
Luckfox Lyra Zero W, pin definition
Luckfox Lyra Zero W, onboard components
  1. USB-C OTG0 port
  2. USER-LED
    for indicating system operation status in the default image
  3. USB-C HOST port
    for connecting USB peripherals
  4. RESET button
  5. BOOT button
  6. Antenna connector
  7. Onboard antenna
  1. DSI display interface
    MIPI DSI 2-lane
  2. 512MB DDR3L
  3. RK3506B
    Multi-core heterogeneous SoC with built-in Triple-core ARM Cortex-A7 + ARM Cortex-M0
  4. Wi-Fi / Bluetooth module
    2.4G Wi-Fi 6 / Bluetooth 5.2 / BLE module
  5. MX1.24 4P header
    can be converted to USB-A HOST port or used for LCD screen power input
  6. TF card slot
  7. 40PIN GPIO header
    Compatible with some Raspberry Pi HATs
  1. USB HUB chip
  2. PMIC
    3-ch power management IC
  1. W25N02KV
    256MB SLC NAND FLASH
Luckfox Lyra Zero W, outline dimensions
Luckfox Lyra Zero W × 1
Luckfox Lyra Zero W
Connectivity
BluetoothBluetooth 5.2 / BLE
Wi-Fi2.4GHz Wi-Fi 6
Memory and Storage
Flash256MB
Memory512MB DDR3L
SOC Features
ProcessorTripe-core@1.2Ghz
USBOriginal USB OTG 2.0 × 1 HUB expanded USB HOST 2.0 × 2
