PLC Based on Luckfox Core3506, Supports Custom Development
Extensive I/O Interfaces and Robust Performance for Industrial Automation
| Processor | RK3506B |
| CPU | Triple-core ARM Cortex-A7 (1.2 GHz) |
| RAM | Onboard 512MB DDR3L |
| Storage | eMMC (8GB) |
| Display | 1.9inch LCD touchscreen, 170 x 320 pixels |
| USB |
USB OTG2.0 x 1 Extended USB HOST2.0 x 1 via HUB |
| Ethernet | 10/100Mbps Ethernet port x 2 |
| Wireless Connectivity | Onboard 2.4 GHz Wi-Fi 6 / Bluetooth 5.2 / BLE |
| CAN | CAN x 1 |
| Serial Interfaces |
RS232 x 1 RS422/RS485 x 1 (Shared port, selectable by wiring) |
| Relay Channels | 2 |
| Relay Contact Form | Normally Open (NO) x 1 Normally Closed (NC) x 1 |
| Relay Contact Rating | ≤10A 250V AC or ≤10A 30V DC |
| Buttons |
Custom button x 1 (Used for firmware update by default) RESET button x 1 |
| Power Input | USB-C input: 5 V |
| Screw terminal power input: 7–24 V DC (wide input voltage range) | |
| PoE input (for PoE Version only): compatible with IEEE 802.3af PoE Standard |
Supports wired and wireless connectivity
Provides RS232 / RS422 / RS485 / CAN / USB and Other Interfaces
Suitable for Data Collection and Reporting, Device Linkage, and Protocol Conversion
Comprehensive Software Ecosystem - Supports Multiple Languages
and Optional Installation of Node-RED, OpenPLC, and Other Software
Access the device management interface via a browser for quick system configuration
Multiple built-in remote access networking solutions enable remote management and debugging
Industrial Control
Smart Home
Smart Agriculture
| Connectivity | |
| Bluetooth | Bluetooth 5.2/BLE |
| Ethernet | 2 x 100Mbps RJ45; ETH1 Supports PoE Input (PoE Version Only) |
| Wi-Fi | Wi-Fi 6 |
| Memory and Storage | |
| eMMC | 8GB |
| Memory | 512MB DDR3L |
| SOC Features | |
| Processor | Triple-core Arm Cortex-A7 @ 1.2GHz |
| Display | |
| Size | 1.9 inch |
| Resolution | 170 x 320 |
| Interfaces & Peripherals | |
| Power Header | USB-C, 5V |
| USB | Native USB OTG2.0 x 1; Extended USB HOST2.0 x 1 via HUB |
| Others | |
| SoC | RK3506B |
