Luckfox Lyra RK3506G2 Linux Micro Development Board, Integrates Tripe-core ARM Cortex-A7 and ARM Cortex-M0 Processors
Processor | Triple-Core Arm Cortex-A7 (1.2Ghz) + Arm Cortex-M0 |
Memory | 128MB DDR3L |
USB | USB OTG2.0 × 2 |
Display | MIPI DSI 2-lane |
GPIO | 24 × Rockchip Matrix IO pins |
Default Storage | Luckfox Lyra: TF card (Not included) Luckfox Lyra B: SPI NAND FLASH (256MB) |
Version and Pinheader options
Kit Selection
- Triple-Core ARM Cortex-A7 32-bit core, with integrated VFP to support single- and double-precision floating-point operations
- Built-in ARM Cortex-M0 MCU design, supports SMP and AMP configuration
- Built-in 128MB DDRL3 for multi-core applications
- The low-speed interfaces adopt Rockchip Matrix IO design, which allows rich function signals to share the limited chip pins, making peripheral circuit adaptation more flexible
- Built-in audio and video codec, supports multiple audio inputs and outputs, providing high-quality audio playback and recording functions
Easier to develop
Integrates TF card slot, DSI interface and USB connector
MIPI DSI 2-lane interface
Compact size, powerful performance, easy to drive large screens
* for reference only, please refer to the Package Content for the detailed part list.
Supports up to 1280 × 800 @ 60Hz resolution.
The Rockchip Matrix IO supports 98 multiplexed functions and allows flexible pinout configuration
Optional for 256MB SLC NAND FLASH
Provides a better user experience
* Only Luckfox Lyra B versions with 256MB Flash, while the Luckfox Lyra versions require an additional TF card (NOT included) for storage.
- USB Type-C connector
for power supply and program burning - ACT-LED
- BOOT button
Press it when powering on to enter download mode - RESET button
- USB MX1.25 4P connector
can be converted to USB Type-A port via an adapter cable
- TF card slot
- RK3506G2
Multi-core heterogeneous SoC with built-in Triple-Core ARM Cortex-A7 + ARM Cortex-M0 - DSI display interface
MIPI DSI 2-lane - W25N02KV
256MB SLC NAND FLASH (for Luckfox Lyra B versions only)
Product Show
Luckfox Lyra / Luckfox Lyra B
OPTIONS Luckfox Lyra (without flash)/ Luckfox Lyra B x1
Luckfox Lyra M/ Luckfox Lyra B M (256MB)
OPTIONS Luckfox Lyra (without flash)/ Luckfox Lyra B (256MB FLASH) with pre-soldered header x1
Luckfox Lyra / Luckfox Lyra B LCD Kit A
- 10.1-DSI-TOUCH-A ×1
- MX 1.25 2PIN to 2.54 3PIN cable x1
- OPTIONS Luckfox Lyra / Luckfox Lyra B ×1
- MX 1.25 2PIN to 4PIN cable x1
- MIPI-DSI-Cable-12cm x1
- FFC 22PIN cable ~200mm (opposite sides) x2
Memory and Storage | |
Memory | 128MB DDR3L(OPTIONS) |
SOC Features | |
Processor | Tripe-core@1.2Ghz |
Interfaces & Peripherals | |
Display Interface | MIPI DSI 2-lane |
GPIO | 24-Pin |
Micro SD | Slot |
USB | USB OTG2.0 |
