Luckfox Pico Ultra RV1106 Linux Micro Development Board, Integrates ARM Cortex-A7/RISC-V MCU/NPU/ISP Processors
$17.99
  • Model: Luckfox Pico Ultra
  • Weight: 0.05kg
  • SKU: 27103
  • Battery: Not included
Luckfox Pico Ultra series, front view Luckfox Pico Ultra series, features
Version Comparison
ModelLuckfox Pico UltraLuckfox Pico Ultra B
ProcessorRV1106G3RV1106G2
NPU1TOPS0.5TOPS
Memory256MB DDR3L128MB DDR3L
Development Board Versions
Luckfox Pico Ultra series, version options
Optional for IPS LCD
Luckfox Pico Ultra series, optional for IPS LCD
LCD Kit connection example
Luckfox Pico Ultra series, LCD Kit connection example
4″ IPS Touch Display Introduction
Capacitive Touch
Supports flexible and responsive touch operation to make development more convenient
LF40 480480 ARK, capacitive touch
LCD Specifications
Model4inch IPS Touch Display
480x480
720x720
Resolution480×480720×720
Communication InterfaceRGB666
SIZE4"
Display PanelIPS
Touch TypeCapacitive
Touch ChipGT911
Brightness400cd/m²
Operation temperature-20~70°C
Contrast ratio380:11000:1
Viewing Angle160°170°
Outline Dimension84.2×84.2mm (H×V)84.0×84.0mm (H×V)
Display area71.86×70.18mm (H×V)71.93×71.93mm (H×V)
Pixel pitch0.1497×0.1462mm (H×V)0.0999×0.0999mm (H×V)
DISPLAY COLOUR GAMUT-68% NTSC
Development Board Introduction
Luckfox Pico Ultra series, integrates RV1106
  • Built-in Rockchip self-developed 4th generation NPU, features high computing precision and supports int4, int8, and int16 hybrid quantization. The int8 computing power of RV1106G3 is 1TOPS, and RV1106G2 is 0.5TOPS
  • Features powerful encoding performance, supports intelligent encoding mode and adaptive stream saving according to the scene, saves more than 50% bit rate of the conventional CBR mode so that the images from camera are high-definition with smaller size
  • Built-in 16-bit DRAM DDR3L, which is capable of sustaining demanding memory bandwidths
WiFi 6 and Bluetooth module
Onboard 2.4GHz WiFi 6 and Bluetooth 5.2/BLE Bluetooth Module, Providing Stable Connection And Efficient Transmission
Luckfox Pico Ultra series, onboard WiFi 6 and Bluetooth module
* the WiFi 6 / Bluetooth module is only available in Luckfox Pico Ultra W / Ultra BW series
Reserved PoE Module Header
Luckfox Pico Ultra series, onboard reserved PoE module header
optional for PoE Module, Supports PoE Power Supply
Provides Both Network Connection And Power Supply for Luckfox Pico Ultra board In Only One Ethernet Cable
Luckfox Pico Ultra series, optional for PoE Module Luckfox Pico Ultra series, supports PoE power supply
* the PoE module is optional, and the switch in the picture above is NOT included.
Luckfox Pico Ultra series, onboard components
  1. USB Type-C connector
  2. USER-LED
    for indicating system operation status in the default image, programmable indicator
  3. BOOT button
  4. RESET button
  5. GPIO header
  6. Onboard microphone
  7. Antenna connector
  8. WIFI/Bluetooth module
    2.4G WiFi 6; BT5.2/BLE Bluetooth module
  9. USB-A Interface
    Switching with USB Type-C by chip, enabled automatically for USB communication when USB-C is not connected
  1. RJ45 100M Ethernet port
  2. Speaker header
    MX1.25 2P connector, supports 8Ω 1W speaker
  3. RGB LCD Interface
  4. CSI camera interface
    MIPI CSI 2-lane
  5. RV1106G3/RV1106G2
  6. KLM8G1GETF-B041
    8GB EMMC
  7. RTC battery connector
  8. PoE module header
  9. PoE module / external power supply header
    for connecting external 5V power supply or PoE module power supply
Luckfox Pico Ultra series, pin definition
Luckfox Pico Ultra series, outline dimensions
Luckfox Pico Ultra / Ultra B
  1. OPTIONS Luckfox Pico Ultra / Ultra B x1
  2. USB Type-A to Type-C cable x1
1Luckfox Pico Ultra
2
Luckfox Pico Ultra / Ultra B PoE Kit
  2. Luckfox PoE module x1
  3. USB Type-A to Type-C cable x1
  4. Screws pack x1
1Luckfox Pico Ultra PoE Kit
2
3
4
  1. OPTIONS Luckfox Pico Ultra W / Ultra BW x1
  2. IPX 2.4G 2DB antenna x1
1Luckfox Pico Ultra W
2
3
Luckfox Pico Ultra W / Ultra BW PoE Kit
  3. IPX 2.4G 2DB antenna x1
  4. USB Type-A to Type-C cable x1
  5. Screws pack x1
1Luckfox Pico Ultra W PoE Kit
2
3
4
5
Luckfox Pico Ultra / Ultra B LCD Kit A
  2. 4inch IPS Touch Display 480x480 pixels x1
  3. FFC cable x1
2
3
4
Luckfox Pico Ultra / Ultra B LCD Kit B
  2. 4inch IPS Touch Display 720x720 pixels x1
  3. FFC cable x1
2
3
4
Luckfox Pico Ultra / Ultra B LCD Kit C
  3. Screws pack x1
  4. 4inch IPS Touch Display 480x480 pixels x1
  5. FFC cable x1
  6. USB Type-A to Type-C cable x1
2
3
4
5
6
Luckfox Pico Ultra / Ultra B LCD Kit D
  3. Screws pack x1
  4. 4inch IPS Touch Display 720x720 pixels x1
  5. FFC cable x1
2
3
4
5
6
Luckfox Pico Ultra W / Ultra BW LCD Kit A
  3. 4inch IPS Touch Display 480x480 pixels x1
  4. FFC cable x1
  5. USB Type-A to Type-C cable x1
2
3
4
5
Luckfox Pico Ultra W / Ultra BW LCD Kit B
  3. 4inch IPS Touch Display 720x720 pixels x1
  4. FFC cable x1
2
3
4
5
Luckfox Pico Ultra W / Ultra BW LCD Kit C
  4. Screws pack x1
  5. 4inch IPS Touch Display 480x480 pixels x1
  6. FFC cable x1
  7. USB Type-A to Type-C cable x1
2
3
4
5
6
7
Luckfox Pico Ultra W / Ultra BW LCD Kit D
  4. Screws pack x1
  5. 4inch IPS Touch Display 720x720 pixels x1
  6. FFC cable x1
2
3
4
5
6
7
Connectivity
BluetoothBluetooth 5.2/BLE
EthernetRJ45 100M (PoE)
Wi-FiWi-Fi6
Memory and Storage
eMMC8GB eMMC
Memory256MB DDR3L
SOC Features
ISP5MP@30fps
NPU1TOPS
ProcessorSingle-core
Audio OuputOnboard microphone, Speaker header
Camera InterfaceMIPI CSI 2-lane
GPIO30-PIN
Other InterfaceType-C
USBType-C
