Luckfox Core3576 Module, Rockchip RK3576 Octa-Core 2.2GHz Processor, Features A big.LITTLE Architecture, 6 TOPS Computing Power NPU, Options For RAM And eMMC
$64.99
  • Model: Core3576
  • Weight: 0.02kg
  • Battery: Not included
Date First Available: 2024-10-31
Luckfox Core3576 Module, front view
ProcessorQuad-core Arm Cortex-A72@2.2GHz + Quad-core Arm Cortex-A53@2.0GHz
RAMOptions for 4 / 8GB LPDDR4X RAM
StorageOptions for 0 / 32 / 64GB eMMC Flash
NPU6 TOPS@INT8, supports INT4, INT8, INT16, FP16, BF16, TF32 mixed operation
GPUARM Mali G52 MC3@0.9GHz, supports OpenGL ES 1.1/2.0/3.2, OpenCL 2.0 and Vulkan 1.1, and built-in high-performance 2D/3D acceleration hardware
ISPBuilt-in 16MP ISP, supports multiple algorithm accelerators such as HDR, 3A, CAC, 3DNR, 2DNR, Sharpening, Dehaze, Enhance, Debayer, and small-angle lens distortion correction, etc.
VideoDecoding: 4K@120fps (H.265/HEVC, VP9, AVS2, AV1); 4K@60fps (H.264/AVC)
Encoding: 4K@60fps (H.265/HEVC, H.264/AVC)
ConnectivitySupports 1000M Ethernet × 2
Expandable for 2.4GHz/5GHz dual-band Wi-Fi 6, Bluetooth 5.2
Video OutputHDMI2.1 (4K@120fps) × 1 / eDP1. 3(4K@60fps) × 1
4-lane MIPI DSI (2K@60fps) × 1
Video InputMIPI CSI DPHY × 2
MIPI CSI D/CPHY
PCIe/SATAPCIe 2.1/SATA3.1 × 2
USBUSB3.2 Gen1 OTG (5Gbps), supports DP protocol
USB3.2 Gen1 interface (5Gbps)
USB2.0 interface
SDIOSDIO3.0 × 2
CANCAN FD × 2
ADCSARADC × 8
Expansion interfacesI2C × 10;
I3C × 2;
UART × 12;
SPI × 5;
CAN × 2;
Multiple GPIOs
Connector260 Pin SO-DIMM Connector
Power input5V DC
Outline Dimensions69.6mm × 45mm
OthersSupports 38KHz infrared input
Low power RTC chip with backup battery input
Note: the actual number of available interfaces may be reduced due to pin multiplexing.
Low Power Octa-Core AIoT Processor
Equipped with high-performance RK3576 processor, integrated with quad-core Cortex-A72 and quad-core Cortex-A53, providing strong performance and high energy efficiency
Luckfox Core3576 Module, with Octa-Core AIoT processor
Equipped with 6 TOPS computing power, easy to convert a variety of neural network models based on TensorFlow, MXNet, PyTorch, and Caffe frameworks.
Luckfox Core3576 Module, Object Recognition demo
Object Recognition
Luckfox Core3576 Module, Face Recognition demo
Face Recognition
Luckfox Core3576 Module, Vehicle Recognition demo
Vehicle Recognition
Luckfox Core3576 Module, Pedestrian Detection demo
Luckfox Core3576 Module, Text Recognition demo
Text Recognition
Luckfox Core3576 Module, Semantic Segmentation demo
Luckfox Core3576 Module, supports a variety of neural network models
Supports 4K Encoding and Decoding
Supports 4K@120fps (H.265/HEVC, VP9, AVS2, AV1), 4K@60fps (H.264/AVC) decoding and 4K@60fps (H.265/HEVC, H.264/AVC) encoding, easy to deal with HD video tasks
Luckfox Core3576 Module, supports 4K encoding and decoding
Supports Three-Screen Display
Supports Three Video Outputs Including MIPI DSI, HDMI2.1 (4K@120fps) Or eDP1.3 (4K@60fps), And Adapting DP Interface Via USB, Enabling Multi-screen Display
Luckfox Core3576 Module, supports three-screen display
Dual Gigabit Ethernet Interfaces
Different types of traffic can be distributed to different network interfaces: one for external Internet connection and another for internal LAN, which improves security and management flexibility
Luckfox Core3576 Module, supports dual gigabit ethernet
Rich Peripheral Interfaces
Adopts SO-DIMM connector, supports a wide range of expansion interfaces such as HDMI, MIPI-DSI, DP, MIPI-CSI, PCIe2.0/SATA3, SDIO, GMAC, USB3.0, USB2.0, I2C, I3C, SPI, I2S, UART, GPIO, etc. providing support for a variety of applications, allowing users to quickly apply it to the projects
Luckfox Core3576 Module, with rich peripheral interfaces
Application Examples
Widely used in edge computing, local deployment of large models, intelligent commercial displays, cloud terminal products, industrial control hosts, automotive electronics, and more
Luckfox Core3576 Module, application examples
Luckfox Core3576 Module, outline dimensions
OPTIONS Core3576 module x 1
Core3576 module
Connectivity
BluetoothBluetooth 5.2
Ethernet1000M Ethernet × 2
Infrared38KHz input
Wi-Fi2.4GHz/5GHz Wi-Fi 6
Memory and Storage
Flash 0/32/64GB eMMC
Memory4/8GB LPDDR4X
SOC Features
GPU0.9GHz
ISP16MP
NPU6TOPS
ProcessorOcta-Core@2.2GHz
Video Decoding4K@120fps
Video Encoding4K@60fps
Camera InterfaceMIPI CSI DPHY; MIPI CSI D/CPHY
Display InterfaceHDMI2.1 / eDP1. 3; 4-lane MIPI DSI
GPIO260 Pin SO-DIMM
USBUSB3.2 Gen1 OTG (DP); USB2.0
Others
Operating Temp.0°C ~ 60°C
Power input5V DC
Storage Temp.0°C ~ 70°C
