7inch HD Capacitive Touch Screen LCD 1024×600 Resolution, HDMI, IPS, Multi-Point Touch
Hot
$42.99
  • Model: 7″ HD Touchscreen
  • Weight: 0.59kg
  • Battery: Not included
Compatible With Multiple devices and systems
Supports all versions of Raspberry Pi, PC, and other devices
IPS Display Panel
Excellent Display Performance With 170° Wide Viewing Angle
Capacitive Touch
up to 5-point touch, depending on the operating system
Save more spaces
gold immersion process
Better appearance | Anti-oxidation | Anti-corrosion | Strong welding
Interface Introduction
Raspberry Pi mounting holes Design
Dimensions
7″ HD Touchscreen Kit x1
Display
Size7inch
Resolution1024×600
Display PanelIPS
Viewing Angle170°
Touch
Touch Point5-Point
Touch TypeCapacitive
Display InterfaceHDMI, HDMI FFC Connector
Power Header3PIN-PH2.0
Touch Header4PIN-PH1.25
USBType-C
Device & System Support
PCYES
Raspberry PiYES
