High Image Quality | High Color Gamut Panel | Built-in Speakers
Supports Raspberry Pi, Luckfox RK3576, PC, and other devices
Working with Raspberry Pi 5
Working with Raspberry Pi 4B
Working with Raspberry Pi Zero
Working with PC
* for reference only, the above host boards are not included.
color gamut of this QLED display is up to: sRGB 90%, NTSC 72%
(* This function is only available on the QLED version)
chroma of QLED increases 58.3%, makes the color more pure, more vivid
due to its inorganic characteristic, the color life of QLED could be up to 60000 hours without color degradation
Up To 5-Point Touch, Depending On The Operating System
Built-in Ferrite High-Quality Speaker, Stereo Sound Effect, Wider Sound Range, Better Sound Quality
Recessed interface design
Metal stand
Anti-Oxidation | Anti-Corrosion | Strong Welding
| Display | |
| Backlight Adjustment | YES |
| Refresh Rate | 60Hz |
| Size | 7inch |
| Resolution | 1024×600 |
| Display Panel | IPS/QLED |
| Viewing Angle | 170° |
| Display Color | 16.7M |
| Display Colour Gamut | 50%NTSC / 72%NTSC |
| Pixel Pitch (H×V) | 0.1506×0.1432 (mm) |
| Touch | |
| Touch Point | 5-Point |
| Touch Type | Capacitive |
| Interfaces & Peripherals | |
| Audio Ouput | High-Quality Speaker |
| Display Interface | HDMI |
| Touch Header | USB |
| Others | |
| Power Consumption | 5V 650mA |
| Power input | 5V |
| Power Interface | USB Type-C |
