7inch DSI Capacitive Touch Display, 720×1280 Pixels, IPS Panel, Optical Bonding Toughened Glass Panel, 10-Point Touch, Anti-Fingerprint Process
  • Model:7-DSI-TOUCH-A
  • SKU:30323
  • $49.99
    In Stock
7″ DSI Capacitive Touch Display
7inch DSI capacitive touch display, front and back view 7inch DSI capacitive touch display, front and back view
The display orientation is portrait by default, 720×1280 resolution (H×V). Change the software config for landscape display.
Device & System Support
7inch DSI capacitive touch display, adopts IPS display panel
connection examples
Working with Raspberry Pi 5
7inch DSI capacitive touch display, working with Raspberry Pi 5
Please connect the FPC cable as shown above, and power the LCD through the GPIO 5V pin
Working with Raspberry Pi 4B
7inch DSI capacitive touch display, working with Raspberry Pi 4B
Please connect the DSI cable as shown above, and power the LCD through the GPIO 5V pin
Working with ESP32-P4-NANO
7inch DSI capacitive touch display, connecting to ESP32-P4-NANO
Working with Luckfox Lyra
7inch DSI capacitive touch display, connecting to Luckfox Lyra
Working with Luckfox Omni3576
7inch DSI capacitive touch display, connecting to Luckfox Omni3576
IPS Display Panel
Excellent Display Performance With 170° Wide Viewing Angle
10-Point Capacitive Touch
7inch DSI capacitive touch display, supports 10-point capacitive touch
  3. Optical bonding, provides clear image, dustproof
  4. Adopts anti-fingerprint panel coating, easy to clean
Supports backlight adjustment via software
7inch DSI capacitive touch display, backlight adjustment demo
Thinner and more space-saving
Integrates the driver circuit into an FPC cable, the total thickness of the LCD is only 9.3mm
7inch DSI capacitive touch display, more space-saving
interface definition
7inch DSI capacitive touch display, interface definition
7inch DSI capacitive touch display, outline dimensions
Display
Size 7inch
Resolution 720×1280
Display Panel IPS
Viewing Angle 170°
Brightness 450cd/m²
Communication Interface DSI
Pixel Pitch (H×V) 0.16967×0.16995mm
Touch
Touch Panel Toughened Glass
Touch Panel Tech Optical Bonding
Touch Point 10-Point
Touch Type Capacitive
Touch Header I2C
  1. 7-DSI-TOUCH-A x1
  2. MIPI-DSI-Cable-12cm x1
  3. MX 1.25 2PIN to 2.54 3PIN cable x1
  4. FFC 22PIN cable ~200mm (opposite sides) x2
  5. MX 1.25 2PIN to 2.54 4PIN cable x1
  6. Screws pack x1
7-DSI-TOUCH-A
