3.5inch Capacitive Touch Display for Raspberry Pi, IPS Panel, 320×480 Resolution, 5-point Touch, Toughened Glass Panel
  • Model:3.5-RPi-LCD-CTP
  • SKU:31566
  • $15.99
    In Stock
3.5inch-RPi-LCD-CTP, luckfox icon
Embedded ST7796S driver and GT911 capacitive touch control chip
3.5inch Capacitive Touch Display for Raspberry Pi, front view
3.5inch Capacitive Touch Display for Raspberry Pi, features
The display orientation is portrait by default, 320×480 resolution (H×V). Change the software config for landscape display.
Device & System Support
Supports Raspberry Pi OS, 5-Point touch, driver provided
3.5inch Capacitive Touch Display for Raspberry Pi, device & system support
Features at a glance
  • 262K color display with 320 × 480 resolution for excellent visual effects
  • High touch screen transmittance, fast response, sensitive touch, and long lifetime
  • Embedded with ST7796S driver chip and GT911 capacitive touch control chip, using SPI and I2C communication respectively, minimizes required IO pins
Operating Voltage 5V Logic Level 3.3V
Display Driver ST7796S Touch Driver GT911
Display Interface 4-wire SPI Touch Interface I2C
Display Panel IPS Display Size 3.5inch
Touch Type Capacitive Touch Points 5-point touch
Display Size 49.36 × 73.84 (mm) Touch Panel Size 61.00 × 92.44 (mm)
Embedded with ST7796S Driver Chip And GT911 Capacitive Touch Control Chip
3.5inch Capacitive Touch Display for Raspberry Pi, touch demo
smooth and stable display
Highly compatible with Raspberry Pi desktop OS, supports smooth and stable operation
3.5inch Capacitive Touch Display for Raspberry Pi, smooth and stable display
IPS Display Panel
Excellent Display Performance, 262K color, wide viewing angle
3.5inch Capacitive Touch Display for Raspberry Pi, adopts IPS display panel
High Refresh Rate
Smooth high refresh rate display, providing a smoother operating experience
Pin Definition
3.5inch Capacitive Touch Display for Raspberry Pi, pin description
Pin Symbol Description
1 NC NC
2 5V 5V power input
3 TP_SDA Touch panel data pin
4 5V 5V power input
5 TP_SCL Touch panel clock pin
6 GND Ground
7 TP_INT Touch panel interrupt pin
8 NC NC
9 GND Ground
10 NC NC
11 TP_RST Touch panel reset pin, low active
12 LCD_PWM LCD PWM backlight pin
13 LCD_RST LCD reset pin, low active
14 GND Ground
15 LCD_DC LCD Data/Command selection (high for data, low for command)
16 NC NC
17 NC NC
18 NC NC
19 MOSI SPI MOSI pin
20 GND Ground
21 MISO SPI MISO pin
22 NC NC
23 SCLK SPI CLK pin
24 CE0 LCD chip selection, low active
25 GND Ground
26 NC NC
Hardware Connection
Connecting with Raspberry Pi 5
3.5inch Capacitive Touch Display for Raspberry Pi, connecting with Raspberry Pi 5
Connecting with Raspberry Pi 4B
3.5inch Capacitive Touch Display for Raspberry Pi, connecting with Raspberry Pi 4B
Connecting with Raspberry Pi Zero 2 W
3.5inch Capacitive Touch Display for Raspberry Pi, connecting with Raspberry Pi Zero 2 W
Outline dimensions
3.5inch Capacitive Touch Display for Raspberry Pi, outline dimensions
Display
Backlight Adjustment YES
Logic Level 3.3V
Refresh Rate 60Hz
Size 3.5inch
Resolution 320×480
Display Panel IPS
Viewing Angle 170°
Brightness 200cd/㎡
Communication Interface 4-wire SPI
Display Colour Gamut 65%NTSC
Pixel Pitch (H×V) 0.153×0.153(mm)
Touch
Touch Chip GT911
Touch Panel Toughened Glass
Touch Point 5-point
Touch Header I2C
Others
Power input 5V
Power Interface GPIO
  1. 3.5-RPi-LCD-CTP × 1
  2. Screws pack × 1
3.5inch RPi LCD CTP
