Luckfox 21.5inch IPS Touch Monitor with foldable stand, 1920 × 1080 resolution, 144Hz refresh rate, 10-point capacitive touch
  • $159.99
21.5inch Portable Touch Monitor
Thin and light design, excellent image quality, comes with stand,
multi-device compatible
 21.5inch Touch Monitor with Stand, front view  21.5inch Touch Monitor with Stand, features
Device & System Support
 21.5inch Touch Monitor with Stand, devices support
Connection Examples
 21.5inch Touch Monitor with Stand, Working with Full-Featured Type-C PC
 21.5inch Touch Monitor with Stand, working with Full-Featured Type-C Smartphone
Working with Raspberry Pi 5
 21.5inch Touch Monitor with Stand, Working with Raspberry Pi 5
Working with Arduino UNO Q
 21.5inch Touch Monitor with Stand, Working with Arduino UNO Q
Working with Jetson Series Board
 21.5inch Touch Monitor with Stand, working with Jetson Series Board
You need to prepare additional DP-to-mini HDMI adapter or cable
* Please make sure that the smartphone or PC itself features a full-featured Type-C port. For reference only, the above controller boards or hosts are NOT included
Full-featured Type-C Port
Supports audio and video transmission, plug and play,
 21.5inch Touch Monitor with Stand, with Full-featured Type-C interface
Computer Dual Screen
for Collaborative Processing
 21.5inch Touch Monitor with Stand, dual-screen operation demo
IPS Display Panel
Excellent display performance, rich display colors, with wide viewing angle
 21.5inch Touch Monitor with Stand, with IPS panel
HDR True Color Quality
Natural color transition, Catching every splendid detail
 21.5inch Touch Monitor with Stand, supports HDR
144Hz High Refresh Rate
144 frames per second for fast response time, upgraded gaming
and movie watching experience
 21.5inch Touch Monitor with Stand, 144Hz high refresh rate
High-quality capacitive touchscreen
  3. Optical Bonding, display well and dustproof
Dual-track Speaker
Ferrite Hi-Fi speaker, larger volume, wider sound range, better sound quality
 21.5inch Touch Monitor with Stand, with dual-track speaker
Smooth Gaming Experience
A good partner for game consoles, better game experience, play video games
with a wider and clearer vision, supports Xbox360 / PS5 / SWITCH etc.
 21.5inch Touch Monitor with Stand, smooth gaming experience
Comes with Foldable Stand
140° Foldable Metal Stand, sturdy and durable,
with non-slip rubber pad at the bottom of the screen, stable to use
 21.5inch Touch Monitor with Stand, comes with foldable stand
Interface Introduction
 21.5inch Touch Monitor with Stand, interface introduction
Outline Dimensions
 21.5inch Touch Monitor with Stand, outline dimensions
Display
Refresh Rate 144Hz
Size 21.5inch
Resolution 1920×1080
Display Panel IPS
Viewing Angle 178°
Brightness 300cd/m²
Display Color 16.7M
Display Colour Gamut 72%NTSC; 86%sRGB
Display Tech HDR
Pixel Pitch (H×V) 0.24795×0.24795(mm)
Touch
Touch Panel Toughened Glass
Touch Panel Tech Optical Bonding
Touch Point 10-Point
Touch Type Capacitive
Audio Ouput High-Quality Speaker; 3.5mm audio jack
Display Interface Mini HDMI、Type-C
OSD Menu Brightness / Contrast Adjustment
Touch Header USB
Others
Enclosure ABS
Power Consumption PD 20V⎓870mA
Power input 5V
Power Interface USB Type-C
Stand YES
  1. 21.5-Touch-Monitor (with stand) x1
  2. Mini HDMI to HDMI cable ~1.5m x1
  3. Type-C dual-plug cable ~1m x1
  4. USB Type-A male port to Type-C male port cable ~1m x1
  6. OPTIONS 35W PD power x1
21.5-Touch-Monitor
