Luckfox 16inch 2K Portable Touch Monitor With Magnetic Protective Case, 2560 × 1600 Resolution, HDR 165Hz Refresh Rate, IPS panel, Optical Bonding, 10-Point Touch
  • $189.99
Thin and light design, excellent image quality, multi-device compatible
16inch 2K Touch Monitor, front view 16inch 2K Touch Monitor with Stand, features
Device & System Support
16inch Portable Monitor with Stand, devices support
Connection Examples
16inch 2K Touch Monitor with Stand, working with Full-Featured Type-C PC
16inch 2K Touch Monitor with Stand, working with Full-Featured Type-C Smartphone
Working with Raspberry Pi 5
16inch 2K Touch Monitor with Stand, working with Raspberry Pi 5
Working with Jetson Series Board
16inch 2K Touch Monitor with Stand, working with Jetson Series Board
* Please make sure that the smartphone or PC itself features a full-featured Type-C interface.
For reference only, the above controller boards or hosts are NOT included
Full-featured Type-C port
Supports audio and video transmission, plug and play,
16inch 2K Touch Monitor with Stand, with Full-featured Type-C interface
Computer Dual Screens For Collaborative Processing
16inch 2K Touch Monitor with Stand, dual-screen operation demo
IPS Wide Viewing Angle, High Color Gamut
Excellent display performance, rich display colors, and wide viewing angle
16inch 2K Touch Monitor with Stand, with IPS panel
HDR True Color Quality
Natural color transition, Catching every splendid detail
16inch 2K Touch Monitor with Stand, supports HDR
165Hz High Refresh Rate
165 frames per second for fast response time, upgraded gaming
and movie watching experience
2K Ultra HD Resolution
Delivers detail clarity several times greater than normal displays
16inch Portable Monitor, 2K ultra HD resolution
Professional-Grade Color Performance
100%sRGB coverage covers more red, green, and blue areas, supports 10-bit
color depth for smoother color gradients
16inch Portable Monitor, supports professional-Grade color performance
High-quality capacitive touchscreen
  3. Optical Bonding, display well and dustproof
Dual-track Speaker
Ferrite hi-fi speaker, larger volume, wider sound range, better sound quality
16inch 2K Touch Monitor with Stand, with dual-track speaker
Smooth Gaming Experience
A good partner for game consoles, better game experience, play video games
with a wider and clearer vision, supports Xbox 360 / PS5 / SWITCH etc.
16inch 2K Touch Monitor with Stand, smooth gaming experience
Comes with Magnetic Protective Case
Comes with a detachable magnetic protective case, supports two adjustable viewing angles
16inch 2K Touch Monitor with Stand, comes with foldable stand
Interface Introduction
16inch 2K Touch Monitor with Stand, interface introduction
Outline Dimensions
16inch 2K Touch Monitor with Stand, outline dimensions
Display
Size 16inch
Resolution 2560×1600
Display Panel IPS
Viewing Angle 178°
Brightness 300cd/m²
Display Color 1.07G
Display Colour Gamut 100%sRGB
Display Tech HDR
Pixel Pitch (H×V) 0.1346 × 0.1346 (mm)
Touch
Touch Panel Toughened Glass
Touch Panel Tech Optical Bonding
Touch Point 10-Point
Touch Type Capacitive
Audio Ouput High-Quality Speaker; 3.5mm audio jack
Display Interface Mini HDMI、Type-C
OSD Menu Brightness / Contrast Adjustment
Touch Header USB
Others
Enclosure CNC
Power Consumption PD 20V⎓520mA
Power input 5V
Power Interface USB Type-C
Stand YES
VESA Wall Mount 75mm
  1. 16-2K-Touch-Monitor (with magnetic protective case) x1
  2. Mini HDMI to HDMI cable ~1.5m x1
  3. Type-C dual-plug cable ~1m x1
  4. USB Type-A male port to Type-C male port cable ~1m x1
  6. OPTIONS 20W PD power x1
16-Touch-Monitor
