Luckfox Pico Ultra W PoE Kit RV1106 Linux Micro Development Board, Integrates ARM Cortex-A7/RISC-V MCU/NPU/ISP Processors - with WiFi6 and Bluetooth Module and PoE Module
$29.99
  • Model: Luckfox Pico Ultra W PoE Kit
  • Weight: 0.01kg
  • SKU: 27399
Luckfox Pico Ultra series, front view Luckfox Pico Ultra series, features
Version options
Luckfox Pico Ultra series, version options
Luckfox Pico Ultra series, integrates RV1106
  • Built-in Rockchip self-developed 4th generation NPU, features high computing precision and supports int4, int8, and int16 hybrid quantization. The computing power of int8 is 0.5 TOPS, and up to 1.0 TOPS with int4
  • Features powerful encoding performance, supports intelligent encoding mode and adaptive stream saving according to the scene, saves more than 50% bit rate of the conventional CBR mode so that the images from camera are high-definition with smaller size
  • Built-in 16-bit DRAM DDR3L, which is capable of sustaining demanding memory bandwidths
WiFi 6 and Bluetooth module
Onboard 2.4GHz WiFi 6 and BT5.2/BLE Bluetooth Module, Providing Stable Connection with Efficient Transmission
Luckfox Pico Ultra series, onboard WiFi 6 and Bluetooth module
Reserved PoE Module Header
Luckfox Pico Ultra series, onboard reserved PoE module header
optional for PoE Module, Supports PoE Power Supply
Provides Both Network Connection And Power Supply for Luckfox Pico Ultra board In Only One Ethernet Cable
Luckfox Pico Ultra series, optional for PoE Module Luckfox Pico Ultra series, supports PoE power supply
* the PoE module is optional, and the switch in the picture above is NOT included.
Luckfox Pico Ultra series, pin definition
Luckfox Pico Ultra series, onboard components
  1. USB Type-C connector
  2. USER-LED
    for indicating system operation status in the default image, programmable indicator
  3. BOOT button
  4. RESET button
  5. GPIO header
  6. Onboard microphone
  7. Antenna connector
  8. WIFI/Bluetooth module
    2.4G WiFi 6; BT5.2/BLE Bluetooth module
  9. USB-A Interface
    Switching with USB Type-C by chip, enabled automatically for USB communication when USB-C is not connected
  1. RJ45 100M Ethernet port
  2. Speaker header
    MX1.25 2P connector, supports 8Ω 1W speaker
  3. RGB LCD Interface
  4. CSI camera interface
    MIPI CSI 2-lane
  5. RV1106G3
  6. KLM8G1GETF-B041
    8GB EMMC
  7. RTC battery connector
  8. PoE module header
  9. PoE module / external power supply header
    for connecting external 5V power supply or PoE module power supply
Luckfox Pico Ultra series, outline dimensions
Luckfox Pico Ultra
Luckfox Pico Ultra x1
Luckfox Pico Ultra
Luckfox Pico Ultra PoE Kit
  1. Luckfox Pico Ultra x1
  2. Luckfox PoE module x1
  3. Screws pack x1
1Luckfox Pico Ultra PoE Kit
2
3
  1. Luckfox Pico Ultra W x1
  2. IPX 2.4G 2DB antenna x1
1Luckfox Pico Ultra W
2
  3. IPX 2.4G 2DB antenna x1
  4. Screws pack x1
1Luckfox Pico Ultra W PoE Kit
2
3
4
Write a review
