Luckfox Pico Ultra W RV1106 Linux Micro Development Board, Integrates ARM Cortex-A7/RISC-V MCU/NPU/ISP Processors - with WiFi6 and Bluetooth Module
$21.99
- Stock: In Stock
- Model: Luckfox Pico Ultra W
- Weight: 0.01kg
- SKU: 26790
Luckfox Pico Ultra RV1106 Linux Micro Development Board, Integrates ARM Cortex-A7/RISC-V MCU/NPU/ISP Processors, Optional For WiFi And PoE Module
Version options
- Single-core ARM Cortex-A7 32-bit core with integrated NEON and FPU
- Built-in Rockchip self-developed 4th generation NPU, features high computing precision and supports int4, int8, and int16 hybrid quantization. The computing power of int8 is 0.5 TOPS, and up to 1.0 TOPS with int4
- Built-in self-developed third-generation ISP3.2, supports 5-Megapixel, with multiple image enhancement and correction algorithms such as HDR, WDR, multi-level noise reduction, etc.
- Features powerful encoding performance, supports intelligent encoding mode and adaptive stream saving according to the scene, saves more than 50% bit rate of the conventional CBR mode so that the images from camera are high-definition with smaller size
- Built-in 16-bit DRAM DDR3L, which is capable of sustaining demanding memory bandwidths
WiFi 6 and Bluetooth module
Onboard 2.4GHz WiFi 6 and BT5.2/BLE Bluetooth Module, Providing Stable Connection with Efficient Transmission
Reserved PoE Module Header
optional for PoE Module, Supports PoE Power Supply
Provides Both Network Connection And Power Supply for Luckfox Pico Ultra board In Only One Ethernet Cable
* the PoE module is optional, and the switch in the picture above is NOT included.
- USB Type-C connector
for power supply and program burning - USER-LED
for indicating system operation status in the default image, programmable indicator - BOOT button
Press it when powering on or resetting to enter download mode - RESET button
- GPIO header
- Onboard microphone
- Antenna connector
- WIFI/Bluetooth module
2.4G WiFi 6; BT5.2/BLE Bluetooth module - USB-A Interface
Switching with USB Type-C by chip, enabled automatically for USB communication when USB-C is not connected
- RJ45 100M Ethernet port
- Speaker header
MX1.25 2P connector, supports 8Ω 1W speaker - RGB LCD Interface
- CSI camera interface
MIPI CSI 2-lane - RV1106G3
Vision processor SoC with built-in ARM Cortex-A7 core - KLM8G1GETF-B041
8GB EMMC - RTC battery connector
- PoE module header
- PoE module / external power supply header
for connecting external 5V power supply or PoE module power supply
Resources & Services
Luckfox Pico Ultra
Luckfox Pico Ultra x1
Luckfox Pico Ultra PoE Kit
- Luckfox Pico Ultra x1
- Luckfox PoE module x1
- Screws pack x1
- Luckfox Pico Ultra W x1
- IPX 2.4G 2DB antenna x1
Luckfox Pico Ultra W PoE Kit
- Screws pack x1
