Luckfox Pico Max RV1106 Linux Micro Development Board, Integrates ARM Cortex-A7/RISC-V MCU/NPU/ISP Processors,256MB Memory
Hot
$14.99
  • Model: Luckfox Pico Max
  • Weight: 0.02kg
  • Dimensions: 72.00cm x 21.00cm x 0.00cm
  • SKU: 25719
ProcessorCortex A7@1.2GHz
NPUPro: 0.5TOPS, supports int4, int8 and int16
Max: 1TOPS, supports int4, int8 and int16
ISPInput 5M @30fps (Max)
MemoryPro: 128MB DDR2
Max: 256MB DDR2
USBUSB 2.0 Host/Device
CameraMIPI CSI 2-lane
GPIO26 × GPIO pins
Ethernet port10/100M Ethernet controller and embedded PHY
Default StorageSPI NAND FLASH (256MB)
Version and Pinheader options
  • Built-in Rockchip self-developed 4th generation NPU, features high computing precision and supports int4, int8, and int16 hybrid quantization. The int8 computing power of RV1106G2 is 0.5 TOPS, and RV1106G3 is 1.0 TOPS
  • Features powerful encoding performance, supports intelligent encoding mode and adaptive stream saving according to the scene, saves more than 50% bit rate of the conventional CBR mode so that the images from camera are high-definition with smaller size, double the storage space
  • Built-in 16-bit DRAM DDR2, which is capable of sustaining demanding memory bandwidths
  • Integrated with built-in POR, audio codec and MAC PHY
Easier to develop
Integrates TF card slot, camera interface and Ethernet port
SLC NAND FLASH
For a better user experience
Application Example
  1. USB Type-C connector
  2. ACT-LED
  3. BOOT button
  4. RESET button
  5. TF card slot
  6. RV1106
    Vision processor SoC with built-in ARM Cortex-A7 core (RV1106G2 for Pro version, RV1106G3 for Max version)
  1. RTC battery header
    MX1.25 connector, for connecting RTC battery
  2. CSI camera interface
    MIPI CSI 2-lane
  3. RJ45 Ethernet port
  4. USB test pads
  5. BOOT test pad
  6. W25N02KV
    256MB SLC NAND FLASH
  7. GPIO header
Product Show
PRODUCTMain chipMemoryNPUISPDefault StorageFEATURES
Luckfox Pico Mini A
RV1103G164MB0.5TOPS, supports int4, int8 and int16Input 4M @30fps (Max)TF card (Not included)Onboard Type-C port, MIPI CSI Interface, GPIO, etc.
Luckfox Pico Mini B
SPI NAND FLASH (128MB)
Luckfox Pico
Luckfox Pico Plus
SPI NAND FLASH (128MB)Onboard Type-C port, MIPI CSI Interface, GPIO, Ethernet port, etc.
Luckfox Pico Pro
RV1106G2128MBInput 5M @30fps (Max)SPI NAND FLASH (256MB)Onboard Type-C port, MIPI CSI Interface, GPIO, Ethernet port, RTC battery header, etc.
Luckfox Pico Max
RV1106G3256MB1TOPS, supports int4, int8 and int16
Luckfox Pico Pro
Luckfox Pico Pro x1
Luckfox Pico Pro M
Luckfox Pico Pro with pre-soldered headerx1
Luckfox Pico Max
Luckfox Pico Max x1
Luckfox Pico Max M
Luckfox Pico Max with pre-soldered header x1
Write a review
