Core3566 Lite Module with wifi and 2GB RAM, Rockchip RK3566 Quad-core Processor, Compatible With Raspberry Pi CM4
$29.99
  • Model: Core3566102000
  • Weight: 0.04kg
  • SKU: 24848
Core3566 Module, Rockchip RK3566 Quad-core Processor, Compatible With Raspberry Pi CM4, Options For RAM / eMMC/ wireless
NPU0.8 TOPS @INT8
GPUArm Mali-G52 2EE
USB 2.0 × 1
PCIe Gen 2 x 1
28 GPIO signals
Operating Voltage5V DC
Dimensions55 × 40 × 4.7mm
Available options
High speed WiFi and Bluetooth
Product details
Onboard Resources
Product show
Ordering Codes
ModelWirelessRAMeMMC Flash
Core35661 = Yes
0 = No
02 = 2GB
04 = 4GB
000 = 0GB (Lite)
032 = 32GB
Core3566104032
Core3566002000×2GB0GB (Lite)
Core3566002032×2GB32GB
Core3566004000×4GB0GB (Lite)
Core3566004032×4GB32GB
Core35661020002GB0GB (Lite)
Core35661020322GB32GB
Core35661040004GB0GB (Lite)
Core35661040324GB32GB
Certificate of Authorization
Resources & Services
Core3566 without WiFi
  1. OPTIONS Core3566 module x1
1
Core3566 with WiFi
  2. Free WiFi antenna x1
1
2
Write a review
Note: HTML is not translated!
Bad Good
